585,996 active members*
4,222 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Wiring diagram for limit switches with g540?
Results 1 to 6 of 6
    Mar 2017
    926
    Please can someone direct me to an accurate wiring diagram for limit switches with a G540 on a 3 axis CNC machine?
    There are multiple diagrams if I google it but they are all different which means I can't trust any of them.
    The diagram on the Gecko site is not helpful because it only shows wiring for a 2 axis machine (with 4 instead of 6 switches).
    If there is a diagram that someone here can confirm is accurate, I would really appreciate a link....
    Mar 2007
    2083
    Re: Wiring diagram for limit switches with g540?
    the diagram on page 8 of the G540 manual just shows home switches for 4 axis
    Attachment 396014
    assuming your using mechanical micro switches not electronic proximity switches
    you can add another normally closed switch to the switches shown in the G540 manual
    Attachment 396016
    note - the switches labeled home switches act as both home & limit switches
    when homing mach 3 will not trigger an e-stop even though the same input is used
    for both home and limit functions
    John
    PS
    Homann designs wiring diagram on 2 PDF pages
    Attachment 396018
    Mar 2017
    926
    Quote Originally Posted by john-100 View Post
    Attachment 396014
    John
    PS
    Thank you. That is exactly what I needed.
    I am using Linux CNC. I am assuming that the wiring would be the same as it is for Mach3?
    Mar 2007
    2083
    I have not used Linux CNC but I think it uses the printer port the same way
    Attachment 396082
    John
    Mar 2017
    926
    John
    It does. I just get a little anxiety about buying peripherals that specifically say they are for use with Mach3, I am assuming that touch plates and limit switches are universal and compatible with many (or most) software platforms but I guess there is one way to find out for sure...
    So far, I am feeling good about my decision to use Linux CNC. It wasn't difficult to install and the interface is not as different to windows as some people said. I am just hoping I can use it with all the accessories I want....
    It's a little annoying that sellers only supply scripts for Mach 3.
    Mar 2007
    2083
    the original IBM parallel printer port connections for Mach 3
    Attachment 396188
    from what I understand both Mach3 & Linux CNC use the first printer port like this -
    the status port to monitor 5 inputs including E-stop at hexadecimal address 379h
    the Data & Control latches provide 12 outputs
    the Data latch at 378h provides 8 outputs that normally sent 8 bit data to the printer (pins 2 to 9)
    the Control latch at 37A h provides another 4 bit output
    if you slave 2 motors it makes sense to ensure they are driven by the same latch !
    in Mach 3 and presumably Linux CNC
    additional printer ports can be configured to use the DATA latch as either 8 outputs or 8 inputs
    the Mach 3 PDF manual can be downloaded here :-
    http://www.machsupport.com/wp-conten...all_Config.pdf
    partial G540 circuit diagram
    Attachment 396190
    from the diagram you can see the limit switch inputs need to be able to ground the input
    ideally N/C switches in series as a broken wire will stop the machine
    or
    N/O switches in parallel -
    the danger a broken wire is not detected until its too late !!
    electro-mechanical micro switches are easy
    it not as easy to use proximity switches :-
    proximity switches with N/C PNP open collector outputs can be wired in series
    the output from the last proximity switch is the positive supply to the proximity switches and will require an additional interface circuit to work with the G540
    ( or other BOB's that work with an input switch to ground)
    proximity switches with N/O NPN open collector outputs
    will easily interface with the G540 as they can be wired in parallel
    and will be connected between the G540 supply negative and the input terminal
    the problem is you would not detect a broken wire
    John
  1. G540 Limit Switch issue, no Limit Switches fitted!
    By Imagineering in forum Gecko Drives
    Last Post: 09-22-2017, 08:21 AM
  2. G540 wiring questions (home an limit switches)
    By itolond in forum Gecko Drives
    Last Post: 09-11-2015, 04:25 AM
  3. wiring diagram for indicator LED/light for limit/homing switches
    By texasdude in forum CNC Machine Related Electronics
    Last Post: 04-28-2014, 05:32 AM
  4. Replies: 33
    Last Post: 02-24-2010, 10:39 PM
  5. need estop wiring diagram and how to for limit switches
    By eloid in forum CNC Wood Router Project Log
    Last Post: 11-06-2007, 03:55 AM
