In times of increasing uncertainty, it is becoming a key criterion for many companies to be able to quickly adapt their production. Flexibility is not only required of employees – the systems also need to be flexibly transformable to new production processes...Go to press info
2020-04-22
Bosch Rexroth achieves stable sales at previous year’s record level in 2019
Bosch Rexroth held up well in 2019 in a difficult environment and despite a sharp drop in incoming orders. At 6.2 billion euros, sales remained stable at the previous year’s record level. The company benefited from a solid core business in hydraulics and the further expansion of its product range in factory automation as an important door opener for new markets...Go to press info
2019-07-11
Bosch Rexroth records major 'Triumph' for world-leading motorcycle manufacturer
For afficionados of two-wheeled transport, the name Triumph conjures up images of speed, power and quality – attributes which have seen motorcycles bearing the iconic Triumph name enjoy multiple successes in national and international motorsport events...Go to press info
2019-06-11
Sense, connect, detect: The new sensor component for the factory of the future
Sensors are the sensory organs of the Factory of the Future, the data that they collect are the raw material for continuous process improvement and equipment effectiveness...Go to press info
2019-05-22
Knuffingen Airport: A million flights and not one delay
Last month, Knuffingen Airport celebrated one million flights. The replica aircraft are accurate down to the tiniest detail and look almost real when taking off and landing...Go to press info
2019-05-13
Scalable automation solutions for greater flexibility in battery production
Scalable automation solutions increase flexibility throughout the value creation process in battery production...Go to press info
2018-09-30
Mikron Multistar CX-24: Flexible for large-scale production
With the Multistar CX-24, Mikron Machining combines the productivity of a rotary transfer machine with high flexibility for smaller batch sizes. For this, Mikron relies on the open CNC system MTX from Rexroth...Go to press info
2018-09-28
Greater availability thanks to smart servicing
As part of the electronification of mobile hydraulics, Bosch Rexroth is developing new, data-based services for all aspects of rail vehicles...Go to press info
2018-09-26
Reducing diesel consumption
Manufacturers of rail vehicles require efficient and easily configurable cooling systems to reduce energy consumption and comply with new and complex emission guidelines...Go to press info
2018-09-24
CNC system MTX with new hardware: Faster to better machining results
Thanks to increased computing power in the control hardware, the CNC system MTX from Bosch Rexroth achieves even shorter cycle times and better machining quality. With the new XM42 embedded controller...Go to press info
2018-08-29
Universally applicable: New Rexroth linear function modules
The newly developed, ready-to-install FMB and FMS function modules from Bosch Rexroth can be used for the majority of handling tasks in mechanical engineering...Go to press info
2018-08-27
ETA-Fabrik: Energy efficiency research for the real world
ETA-Fabrik consumes 40 percent less energy than conventional production. This is the result of the ETA-Fabrik research project run by PTW at the Technical University Darmstadt...Go to press info
2018-06-22
Transport and positioning perfected: linear motor-driven transfer systems from Rexroth
For the highly dynamic transport and exact positioning of materials and workpieces, linear motor-driven transfer systems are the first choice. Bosch Rexroth is enriching this market segment with two innovative solutions at once...Go to press info
2018-06-20
Economical and intelligent
At the Automatica, Bosch Rexroth will present a disruptive package of solutions for Cartesian handling systems which combines a price-optimized motion control system with an innovative operating concept...Go to press info
2018-06-15
Software of the future: Freed from …
…the restraints of hardware – the software of the future. Let’s talk about math for a minute: You once used specialized hardware to do your arithmetic for you – namely, a pocket calculator...Go to press info
2018-06-13
Prepare, simulate, print and optimize with one system
With the MTX CNC system from Rexroth, machine manufacturers have got the entire additive manufacturing process covered. From reading in the CAD data and simulations to the actual printing process...Go to press info
The topic of additive manufacturing is becoming increasingly important in the production of small series and prototypes, as well as in the area of Industry 4.0. Bosch Rexroth also believes in this future-oriented technology...Go to press info
2018-06-01
Rexroth takes users on a digital journey of Linear Motion Technology
Instead of the previously strictly separate work steps in the dimensioning, configuration, start-up, actual use and diagnosis of Linear Motion Systems, Bosch Rexroth...Go to press info
2018-05-10
From condition monitoring to predictive maintenance: turning date to real customer value
Today’s industry is marked by a steady buzz about connectivity and the Internet of Things, frequently summarized as Industry 4.0. New solutions appear all the time...Go to press info
Rexroth will display a unique system for subsea actuation in booth #2805 at the Offshore Technology Conference (OTC) in Houston, Texas, from April 30th to May 3rd...Go to press info
2018-04-27
Bosch Rexroth presents collaborative robot based on KUKA
Bosch Rexroth continues to expand its portfolio of Automatic Production Assistants (APAS): With the APAS assistant, the company now also integrates KUKA technology into its product range...Go to press info
2018-04-25
IT-supported individual product assembly and process optimization
In the factory of the future, business and production processes are growing ever closer together. Bosch Rexroth supports the essential flow of data from IT to individual assembly stations...Go to press info
2018-04-23
I4.0 solution with new possibilities
Many machines and plants have still not entered the digital age. But they need to be networked in order to take advantage of the benefits of the Industrial IoT...Go to press info
2018-04-06
Flexible, continuous production
The growth markets of energy storage and printed electronics are characterized by considerable pressure in terms of time, quality and costs...Go to press info
2018-04-04
Largest flow on the market
Rexroth is raising the bar in performance and communication for hydraulic actuators with its new generation of WRC-4X directional cartridge valves...Go to press info
2018-03-05
Bosch strengthens its operations in Africa with acquisition in industrial technology
The Bosch Group is strengthening its business in Africa and further expanding its industrial technology portfolio on the continent...Go to press info
2018-03-01
Bosch Rexroth delivers advanced motion platform for Renault simulator
Bosch Rexroth, the leading company in drive and control solutions, is supplying one of the most advanced motion platforms for a new Renault automotive simulator being constructed by system integrator company AV simulation...Go to press info
2018-02-27
Bosch Rexroth training systems make companies fit for Industry 4.0
Industry 4.0 and the Internet of Things will rapidly change the way work is carried out in factories and production facilities...Go to press info
2018-02-23
Uniform travel behavior despite different drive sources
The torque control interface system from Bosch Rexroth offers the opportunity to decouple the drive technology from the fork lift truck driving strategy...Go to press info
2018-02-21
Mexico: Implementing a modernization drive for industry and infrastructure
In recent years, Mexico has developed into a powerhouse in the south of North America. In many cases the country has given impulses for the economic development of Middle and South America...Go to press info
2018-02-19
Rexroth offers digitalization of analog interfaces in hydraulics via IO-Link
Reduced connection costs at increased availability: Rexroth harnesses the advantages of the IO-Link open standard also for hydraulic actuators and sensors...Go to press info
2018-02-17
Working hydraulics from Bosch Rexroth sets Internet of Things in motion
The Internet of Things (IoT) is gaining enormous importance in logistics. Furthermore, the connection of virtual cloud-based business transactions with concrete logistics processes is rapidly progressing...Go to press info
Bosch Rexroth has introduced a new system concept of electro-hydraulic drives targeted at large civil engineering and infrastructure projects, such as ship locks and movable bridges...Go to press info
2017-12-12
Connected automation across the board
With the latest expansion of the Connected Automation range, Bosch Rexroth will introduce six comprehensive solution programs at the SPS IPC Drives... Go to press info
2017-12-10
Smart software and hardware for the industrial IoT
Network new and existing machines efficiently and make them transparent. The IoT Gateway software V2 from Bosch Rexroth achieves this with particular precision and cost-effectiveness...Go to press info
2017-12-08
Motors for intelligent drives
Intelligent, powerful and flexible: The new MS2N servo motors are now also available with an integrated encoder in SIL3 PLe ...Go to press info
2017-12-06
Software drives innovation
Vertical and horizontal connectivity, digital engineering, economic production of very small batch sizes – without software, these core characteristics of Industry 4.0 would be inconceivable...Go to press info
2017-12-04
Flexible, robust, easy to connect: Industrial PCs from Rexroth
With new generation PR, VR, DR industrial PC platform, Bosch Rexroth sets new standards in the low and middle power range in terms of cost-effectiveness...Go to press info
2017-11-14
Bosch Rexroth opens Industry 4.0 Innovation Center
Bosch Rexroth opened China’s first Innovation Center focusing on digital and connected industry in Chengdu. The company demonstrates how Rexroth's solutions for Industry 4.0 significantly enhance processes in production from retrofit to the factory of the future...Go to press info
2017-10-30
New functions without additional components
Although originally developed for other vehicle types, High Level Braking (HLB) is now also available for fork lift trucks...Go to press info
2017-10-26
Testbed Award for TSN Testbed
TSN Testbed from the Industrial Internet Consortium wins the Testbed Award at the IoT Solutions World Congress in Barcelona...Go to press info
2017-10-24
The assistance system ActiveAssist is revolutionizing the manual workstation
Bosch Rexroth places the focus of Industry 4.0 on people: With the ActiveAssist assembly assistance system, Rexroth is combining its years of experience in the fields of lean production and ergonomic workstation design and is expanding on this with pioneering Industry 4.0 intelligence...Go to press info
2017-10-22
Fit for one-point lubrication and challenging applications
The third generation of MKK and MKR Linear Modules from Rexroth provides a considerably expanded range of equipment options for the familiar space-saving dimensions of the previous series...Go to press info
2017-10-20
ActiveMover with linear motor for quick planning
It is already in use in numerous sectors: highly productive transfer system for practically all tasks imaginable...Go to press info
2017-10-18
Rexroth is expanding its range of eTools
What do the configuration of a Linear Motion System and online shopping have in common? In the case of Bosch Rexroth, the answer is easy: Thanks to numerous intuitive eTools, selecting, dimensioning and ordering components and systems for Linear Motion Technology is just as easy and convenient as shopping online in general...Go to press info
2017-10-16
Nokia and Bosch research data speedway for factory of the future
Machine communication in real time: at the European Digital Summit in Tallinn, Estonia, Bosch and Nokia are showcasing a demonstration that combines the upcoming 5G mobile communications standard with Industry 4.0 solutions...Go to press info
2017-10-02
New welding control generation PRC7000 from Rexroth
Process safety and the highest quality at the welding spots are the core requirements for welding processes in the automotive and household appliance industry. With the new welding control family PRC7000, Rexroth has further improved its proven control and monitoring concept...Go to press info
2017-09-27
Valuable data from the machine tool
Both the users and manufacturers of machine tools are very keen to collect sufficient machine data in order to visualize and optimize the manufacturing processes and plant efficiency...Go to press info
2017-09-25
Analyze real time data easily on site
With the Data Analytics Server (DAS), Bosch Rexroth presents a turnkey analysis and monitoring solution for new and existing machines. The real time data captured can be saved, evaluated and clearly visualized close to the machine. Sensitive information can therefore remain in the company...Go to press info
2017-09-11
A most rewarding display of customer loyalty
Bosch Rexroth, the leading company in drive and control solutions, has been awarded a new contract to install two wave generator systems for Indonesian Hydrodynamic Laboratory (IHL), an advanced research laboratory of BPPT (The Agency for the Assessment and Application of Technology)...Go to press info
2017-09-09
Bosch Rexroth expands laser cladding capabilities for cylinder rods
Prof. Dr. Eckhard Beyer, head of the Fraunhofer-Institute for Material and Beam Technology IWS in Dresden together with Bernd Bodenstedt Technical Plant Manager Bosch Rexroth Boxtel, officially released the enhanced laser cladding process at Bosch Rexroth’s cylinder plant in the Netherlands...Go to press info
2017-09-08
KLM, EDM and Rexroth sign agreement for new cabin crew emergency trainer
On Thursday August 24th, 2017, at a ceremony held by KLM in Amsterdam, the Netherlands, Bosch Rexroth, the leading company in drive and control solutions, signed an agreement with KLM and EDM to supply the motion platform solution for KLM’s new cabin crew emergency trainer...Go to press info
2017-09-06
The ‘Next Generation Gangway’ at work in the Irish Sea
Barge Master and Bosch Rexroth’s ‘Next Generation Gangway’ is in operation on the subsea-support walk-to-work vessel VOS Start from Vroon Offshore Services...Go to press info
2017-09-04
Bosch Rexroth awarded as Innovator 2017
Bosch Rexroth is one of the most innovative German companies. This is the result of a survey of 2,000 representatives of innovative award winning companies, 250 experts of the Berlin Institute for Innovation and Technology...Go to press info
2017-08-31
Hydraulic commissioning automated to a great extent
Commission electronified hydraulics easily, even without in-depth knowledge of fluid technology: this is now possible with a new software assistant from Rexroth...Go to press info
2017-08-28
The factory of the future is in Spessart
The "factory of the future" is no longer a vision from the distant future. But it is also not a new building free of people with futuristic machines and equipment. Rather, it is now being implemented in the manufacturing halls of today by IT professionals, specialists for production systems, employees and employee representatives...Go to press info
2017-08-08
Connected Automation without limits
How can machine builders increase the Overall Equipment Effectiveness (OEE) and make use of machine data analytics for development, sales and service? Bosch Rexroth answers questions like these with a new i4.0 showcase...Go to press info
2017-07-24
Focus on upgrade and retrofit of hydraulic systems
Following the demands of their customers to work with increased cable lengths, Blue Offshore, a rental company for specialized cable laying equipment, decided to upgrade the capacity of its existing equipment... Go to press info
2017-07-12
Large Electric Drives from Rexroth are certified for marine applications
It verifiably meets all of the requirements for use in ships and offshore equipment: Resistant to vibrations, humidity and electromagnetic disturbances...Go to press info
2017-07-05
Bosch Rexroth introduces the latest generation of the transfer system TS 5
With the latest edition of its transfer system for heavy loads, Rexroth has demonstrated impressively how something good can be made even better: By optimizing existing components and integrating important new modules into the portfolio, the company has made the TS 5 conveyor system more flexible – and able to meet the requirements of an even broader range of industry sectors...Go to press info
2017-06-30
Highly wear resistant cylinder rod coating for industrial and civil engineering applications
Bosch Rexroth introduces laser cladded Enduroq 1 coating for hydraulic and hybrid cylinders to substitute chrome and nickel chrome layers...Go to press info
2017-06-28
Secure motion with collision control
Modern stage technology enables increasingly challenging motion sequences with numerous complex drives. These sequences often include multi-dimensional and interdependent motions...Go to press info
2017-06-26
Get the right runner blocks with digital turbo power
Bosch Rexroth has expanded its series of completely digital eTools for linear motion technology: The new online configurator for runner blocks depicts the company’s full range of ball and roller rail systems...Go to press info
2017-06-21
Bosch Rexroth keeps its ‘Eye’ on the next generation of engineers
Another group of young engineers has completed a unique training course in association with Bosch Rexroth, equipping them with a combination of theoretical and practical skills in hydraulics...Go to press info
Leading drive and control specialist Bosch Rexroth has reported two years of maintenance-free production at its plant in Schweinfurt, Germany, following the installation of its own Integrated Measuring Systems (IMS), a move that has saved the company tens of thousands of Euros in maintenance and running costs...Go to press info
2017-06-07
Bosch Hits the Road with connected hydraulics UK Tour
A UK Tour, kicking off in June 2017, aims to bring design engineers and service engineers up to speed with a range of modern hydraulic technologies, including connected hydraulics, fluid management and fluid competence and servicing...Go to press info
2017-06-04
Survey reveals mojor training gaps in UK industry
A survey commissioned by drive and control specialist Bosch Rexroth has revealed worrying gaps in training provision and readiness for Industry 4.0 in the UK engineering and manufacturing sectors...Go to press info
2017-06-02
Bosch Rexroth prepares existing facilities for Industry 4.0
Leading drive and control specialist Bosch Rexroth has successfully reduced downtime costs by 25 percent at its factory in Homburg, Germany, after retrofitting production test rigs, some of which are up to ten years old, with Rexroth’s latest IoT Gateway technology...Go to press info
2017-05-31
Five nominations for Rexroth in major industry awards
Leading drive and control specialist Bosch Rexroth is celebrating after being shortlisted for no less than five categories at the prestigious Motion Control Industry Awards 2017...Go to press info
2017-05-27
Bosch Rexroth sets the bar at the inaugural Industry 4.0 Summit
Leading drives and controls specialist Bosch Rexroth demonstrated the opportunities Industry 4.0 can provide to visitors attending the Industry 4.0 Summit at the Manchester Central Convention Centre...Go to press info
2017-05-25
New filtration materials deliver enhanced performance with longer service life
Leading drive and control specialist Bosch Rexroth has introduced a new range of hydraulic filter elements incorporating new materials that deliver optimum performance while reducing operating costs through increased service life...Go to press info
2017-05-22
Rexroth reminds industry of the importance of best practice in hydraulic fluid selection
Leading drive and control specialist Bosch Rexroth has restated the importance of choosing correctly rated hydraulic fluids to optimise performance and safety in mobile applications...Go to press info
2017-05-12
2017-05-10
Five nominations for Rexroth in Major Industry Awards
2017-05-09
The importance of best practice in hydraulic fluid selection
2017-05-01
Bosch Rexroth software connecting off-highway vehicles to the Internet of Things
Leading drive and control specialist Bosch Rexroth is expanding its Internet of Things software capabilities to off-highway vehicles used in construction and agriculture, which will increase fuel efficiency, automate complex or hazardous processes and cut maintenance costs...Go to press info
2017-04-26
2017-04-24
2017-04-13
Bosch Rexroth’s global effort key to Panama Canal expansion
At the time, this project was the world’s largest construction site and consisted of 22km of interconnected piping...Go to press info
2017-04-11
Bosch Rexroth to deliver speech at Industry 4.0 summit
Leading drives and controls specialist Bosch Rexroth will be delivering a speech at the Industry 4.0 Summit, one of the largest gatherings of solutions providers, innovators and technology buyers in Europe...Go to press info
2017-04-01
Bosch Rexroth delivers a drive & control solution for a Japanese
Bosch Rexroth has received an order from GustoMSC to engineer, manufacture and commission the drive and control system for GustoMSC's most recent model in its successful series of continuous jacking systems. It is intended for a Japanese construction vessel...Go to press info
2017-03-29
Industry 4.0 can't be done single-handedly
At the Hack Challenge Manufacturing, around 100 participants searched for new ways to achieve higher overall system effectiveness with state-of-the-art tools such as the Rexroth IoT gateway...Go to press info
2017-03-27
Bosch Rexroth will showcase its Industry 4.0 at the Future EXPO
Bosch Rexroth’s Connected Automation mini assembly line will be providing a live demonstration of Industry 4.0 in action at the exhibition, which will be held at the Manchester Central Convention Complex...Go to press info
2017-03-10
Bosch Rexroth at CONEXPO/IFPE in Las Vegas
Bosch Rexroth will showcase a variety of new systems, products and technology during CONEXPO/IFPE March 7-11, 2017 in Las Vegas, including the new iCube display as well as Genius Cab, an innovative wheel loader cabin concept developed by Bosch and five other companies...Go to press info
2017-01-17
The mountain saw
Without traffic disruption, on the Autostrada Adriatica, which connects the north of Italy to the heel of the boot, the two tunnels of the Montedomini Tunnel have been widened from two to three lanes...Go to press info
2017-01-10
Higher filtration effect and a longer service life
For failsafe operation of hydraulic systems, optimum filtration of the fluid is essential. 80 % of all failures can be traced back to contaminated fluid. The responsible particles are not visible to the naked eye. New filter media of the fifth generation by Rexroth reliably retain these contaminations...Go to press info
2016-11-16
IndraDyn S – MS2N synchronous servo motors extended by additional variant
Modern machine concepts require high-performance drive systems which are flexibly configurable. Consequently, Rexroth has extended their extensive range of the newly designed IndraDyn S synchronous servo motors of the MS2N series with maximum torque from 4 Nm to 360 Nm by force-ventilated and water-cooled variants...Go to press info
2016-11-08
Bosch Rexroth’s Fountain Inn Facility Named Assembly Plant of the Year
The world-class plant was chosen for the 13th annual award in September for a robust combination of lean manufacturing principles, technological advances, environmental initiatives, employee training programs and community involvement...Go to press info
2016-02-23
Real-world Industry 4.0 Training
The mMS4.0 training system illustrates the process steps of Industry 4.0 production.
Training courses, training systems and media from Rexroth help to prepare technical training and further education for Industry 4.0Go to press info
This website uses cookies
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
