Anyone who prioritises cost-effectiveness, process security and flexibility in their user requirements specification can rest easy, as this is precisely what the extremely soft-cutting MaxiMill 271 tool system from CERATIZIT delivers. It can be used for a wide variety of applications and offers a range of effective options to produce top quality surfaces. In addition, wear is effectively reduced and chips are quickly removed from the hot zone.
Face, slot and chamfer milling are what the MaxiMill 271 does best. It is available as a face mill with a 45° approach angle or as a high-speed tool with a 17° approach angle. The result is a product portfolio consisting of fine and coarse pitch holders that offers a range of flexible application options. The MaxiMill programme has now been expanded in line with market expectations by the addition of the 12 mm system size extension. The small size allows more indexable inserts to be attached to the tool holders, which in turn results in longer tool life and higher chip removal rates.
The power of eight
With eight usable cutting edges on each indexable insert, the double-sided MaxiMill 271-12 face milling system is extremely cost-effective. The cutting edges are sturdy and robust and consequently achieve high cutting speeds and provide the highest levels of process security. The tight manufacturing tolerances of the tool holders are one of the main reasons why MaxiMill 271 milling cutters produce the best face and concentricity properties. Perfectly quiet running is achieved through the irregular pitch of the base body, while the Masterfinish geometry of the precision-ground indexable inserts enables the outstanding surface qualities of the MaxiMill 271-12 to shine through. The indexable index grades and chip breaker geometries for the ISO categories P, M, K and S mean the system can be used across a broad range of applications.
Q – a case for performance agents
Trials using comparable competitor tools provided conclusive results: in unalloyed S355 structural steel, a 125 mm diameter MaxiMill 271 face miller returned a 50% higher feed per tooth fz; the CERATIZIT system exhibited an increase of 200% at cutting depth ap. There's no holding the MaxiMill in terms of chip removal rates (Q) either: the tool increases these by 430% (523 cm³/min as opposed to 97 cm³/min), resulting in 50% more completed components. Maximum performance like this is reserved solely for MaxiMill 271 professionals – thanks to the chip removal licence!
For more information about the MaxiMill 271-12, see the UP2DATE catalogue from CERATIZIT (September 2019 edition).
CERATIZIT – With passion and a pioneering spirit for carbides
For more than 95 years, CERATIZIT has been a pioneer in the field of ambitious hard material solutions for machining and protection against wear. The private company, with registered offices in Mamer, Luxembourg, develops and produces highly specialised cutting tools, indexable inserts, rods made from hard materials and wearing parts. We are the global market leader in various application segments for wearing parts and are successfully developing new carbide, cermet and ceramic grades, for example in woodworking and stone working.
With more than 9,000 employees at 34 production facilities worldwide and a sales network with over 70 branches, the Group is a global player in the carbide sector. Our international network also includes subsidiaries KOMET, WNT, Becker Diamantwerkzeuge and Stadler Metalle, as well as the CB-CERATIZIT joint venture. As a technology leader, we continuously invest in research and development and hold over 1,000 patents. Our innovative carbide solutions are used in the mechanical engineering and tool making sectors, in the automotive industry, the aviation and aerospace industry, and in the medical industry.
We are represented on the market by our seven flagship brands, Hard Material Solutions by CERATIZIT, Toolmaker Solutions by CERATIZIT, Tool Solutions by CERATIZIT, Cutting Solutions by CERATIZIT, KOMET, WNT and KLENK.
www.ceratizit.com \ www.kometgroup.com \ www.wnt.com \ www.klenk-tools.de
Published on behalf of
CERATIZIT Deutschland GmbH
Marketing \ Communications
Daimlerstraße 70 \ 87437 Kempten \ Germany
T. +49 831 57010-3405
F. +49 831 57010-3649
E. [email protected]
