532,339 active members*
2,393 visitors online*
Login Register
EMCO GmbH - Banner
EMCO GmbH News
The New EMCOTURN E65: European Cutting-Edge Technology at the Best Possible Price
The EMCOTURN E65 in its new design has been completely re-engineered and optimised. It now includes a Y-axis with a stroke of 80 mm, thus enabling to perform complex milling operations. Due to the use of combined tool holders, it is now possible to increase the number of tools at the turret. As absolute highlight, the EMCOTURN E65 is now available with a counter spindle instead of the automatic tailstock. This is the first time that components can be completely finished in the EMCO entry-level class. The EMCOTURN E65 can, depending on the customer’s requirements, be equipped with a tailstock, driven tools, Y-axis, C-axis, a bar loader package and much more. Customers can choose between either a SIEMENS or FANUC control. And all this in typical EMCO top quality.
HALLEIN – Getting started in complete processing - The EMCOTURN E65 in its new design has been revised from the ground up and optimised. It now includes a Y-axis with a stroke of 80 mm for complex milling operations and with the combined tool holders, more tools fit the turret. As absolute highlight, the EMCOTURN E65S is now available with a counter spindle instead of the automatic tailstock. The new design allows, for the first time in the EMCO entry-level class, components to be completely finished.
The EMCOTURN E65 is part of EMCO’s E-series. This series has been strictly designed according to EMCO’s maxim of “Design to Cost”: the customer is given the highest possible practical value at the lowest cost possible. All components that contribute to the performance, precision and durability of a machine are optimized, while at the same time focusing on the substantial features the customer requires.
In line with EMCO’s philosophy of “Made in the Heart of Europe”, all machines are developed and produced entirely in Central Europe in cooperation with European brand manufacturers, all of whom fulfill the highest standards regarding quality, productivity and economy.
Depending on the make, the EMCOTURN E65 forms the basis for efficient machining of precision and machined parts. The range of manufactured workpieces ranges from  hydraulic / pneumatic components to machines as well as engine and automotive parts, all the way to components from the field of biomedical engineering or the fields of materials and bulk material handling. Friction and antifriction bearing parts are just a few more examples of the nearly endless possibilities.
Machine Configuration
This compact 2-axes CNC lathe is designed for machining barstock parts of up to a diameter of 65 (95) mm and chuck parts of up to diameter 250 (400) mm. Among the properties of the spindle are its high drive power and great speed range, as well as its thermal stability. The tool changer contains 12x VDI 30 (VDI 40) axial stations.
If desired, all 12 stations can be powered. Synchronised thread cutting and polygonal turning are just a few of the numerous possible operations which can be easily carried out because of this. The work area not only permits free chip f but also promotes work ergonomics. The guideways are completely covered and therefore fully protected.
To facilitate efficient manufacturing, the EMCOTURN E65 is equipped either with a bar loader package with the short bar loader EMCO COMPACT LOAD E65, part catcher, an alarm lamp and interface, or with the EMCO TOP LOAD 10-65/3200 for automatic loading of bar material with a diameter of 10 to 65 mm and a length of up to 3.2 meters.
The EMCOTURN E65 is available in various versions: with and without driven tools, as well as with and without Y-axis. As for the control, customers have the choice between the SIEMENS 828D including Shopturn or the FANUC 0iTF including Manual Guide i.
Technical Data:
EMCOTURN 65
Max. bar capacity                       65 (95) mm
Max. chuck size                             200 (250) mm
Max. speed Main spindle               5000 rpm
Max. speed driven tools                 5000 (4500) rpm
Max. drive power main spindle      17 / 22 kW
Max. drive power driven tools        6,7 kW
Max. Traverse path X/Z                 260 / +- 40/ 610 mm
Rapid speed X/Z                            30 / 15 / 30 m/min
Number of tool adapters                12 x VDI 30 (VDI 40)
Number of driven tool positions     12
Machine versions:
• Choice of control: FANUC or SIEMENS
• E65: Basic version without driven tools and C axes with tailstock
• E65 M: Basic version with driven tools, C axes and tailstock
• E65 MY: With driven tools, C axes, Y axes and tailstock
• E65 SM: With driven tools, C axes and counter spindle
• E65 SMY: With driven tools, C axes, Y axes and counter spindle
Responsible for the content of this press release: EMCO GmbH
Contact
EMCO GmbH
Salzburger Straße 80
A-5400 Hallein-Taxach
Austria
+43 (0)6245 891 0
+43 (0)6245 86965
Route planner
Route planner
