585,981 active members*
4,196 visitors online*
Login Register
EMUGE-FRANKEN Forum
Uncategorised CAD Discussion > Dimension Values?
Results 1 to 8 of 8
    Dec 2009
    36
    Dimension Values?
    Hi Guys
    Not new at using this software, but it's got me puzzled this time. Dimension Values I've turned on and off at time's to see what my part might look like when put together. Now old drawings have the dimension arrows but no values, even new drawings same thing arrows but no values. Need help thanks
    Oct 2008
    406
    Quote Originally Posted by 1armsbandit View Post
    Hi Guys
    Maybe Alibre has the same problem as CorelDraw. The dimensions are there but in so small a font they show up as a tiny dot when the entire drawing is viewed.
    Bob
    "Bad decisions make good stories."
    Dec 2009
    36
    No, I know its not that because I can zoom in and out of the drawing mode, if it was small i would see something, thanks for the thought.
    Mar 2010
    I wonder if this is to indicate dissociativity from the part? Most software packages will show the dimensions in a particular color to show that it has lost the corresponding part edges. Perhaps Alibre just does not display the value.
    Jun 2006
    3063
    Alibre usually displays dimension info in red when it has been disassociated.
    The OP should search the Alibre user forum for resolutions to this problem. Seems like video drivers might have been the culprit for others in the past.
    Mike
    Mar 2010
    I would look under properties and change the dimension font, could be its not installed on the OPs computer.
    Dec 2009
    36
    It does show up in red when i hover over the arrows with no values, its never happened before. I've had this software for couple years now, and I keep the video drivers up to date.
    Mar 2010
    7
    Re: Dimension Values?
    Hi, I've been using Alibre for some years and never had a problem until today, all my arrows are there but no dimensions???? Did you ever get to the bottom of this? Thanks for any help you can offer.
  1. G2/G3 values
    By Technical Ted in forum Mastercam
    Last Post: 03-10-2012, 12:17 AM
  2. H and D values
    By dfearnow in forum Mastercam
    Last Post: 02-02-2012, 04:36 PM
  3. Need to know this dimension of DMU 50e
    By NCexplorer in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-21-2009, 11:17 AM
  4. need help with I and K values
    By rod88 in forum MetalWork Discussion
    Last Post: 06-08-2009, 10:06 PM
  5. - r values
    By minner slinner in forum BobCad-Cam
    Last Post: 05-06-2008, 02:09 AM
