Originally Posted by
mactec54
Yes, I'm not new to this I repair VFD Drives, V/F control normally works best for these 400Hz Spindles most VFD Drives that have Vector Control, do not support 400Hz some will work up to 300Hz though some of the more expensive VFD Drives work well using Vector Control for the 400Hz 800Hz spindles
It's very easy to change the V/F Torque Curves first you have to have it run to see if it needs to be changed most don't,
Correct Grounding will not change much, but is a requirement, for any install like this, it also depends how much rotor voltage there is also as this has to go to Ground, if this is high in your spindle then it will cause a high current Fault
Fues and not normally used a Breaker is superior, if one of your Fues blow when you spindle is at full speed you will damage the VFD Drive and sometimes the Spindle this is why Fuses are not used
You should get the cheaper VFD Drive like the Huanyang this will work well with your spindle and not cost very much, high cost VFD Drives are not much better than some of the cheaper VFD Drives, it's your choice
It's quite clear in the manual how to wire your VFD Drive, Note your regular Fuse is not a Disconnect, which is a normal requirement for any install like this
Molded-case circuit breaker (MCCB) or fused disconnect:
? A molded-case circuit breaker or fused disconnect must be installed
between the AC source and the inverter that conforms to the rated
voltage and current of the inverter to control the power and protect the
inverter.
Just remember the Parameters must be set correct before applying Power to these Spindles or you will damage the VFD Drive or the Spindle sometimes both can be Damaged
