544,018 active members*
2,367 visitors online*
Results 1 to 6 of 6
    Junior Member
    Aug 2012
    173
    12" x 12" piece on PCNC 1100?
    Looking to mill some plates where the overall size will be close to 12 x 12 with the milling slightly over 8 x 8 in the center of the parts. I see the travel on the machine is 9.5" so that is ok but wondering if I will have trouble with the part hitting the column or other parts of the mill. I looked a bit for some dimensions of the machine details but didn't find it. A local maker space has the mill but need to figure out if it's big enough. Another has a Bridgeport 2216 but it's a more complex machine to run and that space isn't as convenient.
    Jun 2005
    565
    Re: 12" x 12" piece on PCNC 1100?
    Quote Originally Posted by Jim27 View Post
    Spindle Centerline to Column is the number you want. It's 11" on the spec sheet (of the 1100M I think the others are the same), so the machine can theoretically do what you ask in one setup. How you do the workholding (and if things get tight, how large a cutter you can get away with) are going to be the issues and that will depend on what's on the machine and what's available.
    Junior Member
    Aug 2012
    173
    For work holding - Since the table is plenty long (side to side) I planned to just clamp to the table on the sides. I don't need to machine near the edges. I also don't need to run large cutters.
    Jun 2005
    565
    Well... large cutters actually give you a little more machinable area since you can cut up to the radius of the cutter further away from the spindle centerline, but if you don't need that, then no worries.
    Junior Member
    Apr 2013
    1782
    Of course larger cutters have the downside of reducing the maximum size if you need to machine around the outside of a piece (or machine a raised feature in the middle).
    Gold Member
    Jun 2006
    3090
    I recently had a job with a workpiece that exceeded the available X travel by several inches. I located a 123 block flush against one edge of the work, trammed it parallel to Y along the inside edge and located my X0 along that inside edge. The part had generous tolerances so may not be a good solution for tight requirements, but it give some ideas.
  1. 2" face mill does this spped and feed seem right? on pcnc 1100
    By LSX in forum Tormach Personal CNC Mill
    Last Post: 10-24-2020, 03:13 PM
  2. How do you get the spindle to turn on with a PCNC 1100 for "maual" milling?
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 06-03-2013, 05:43 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 05-06-2013, 09:59 AM
  4. Replies: 1
    Last Post: 03-24-2013, 04:21 PM
  5. WTB: 18" diameter .125~ wall stainless tubing, 18" long piece
    By m-134b in forum Want To Buy...Need help!
    Last Post: 11-01-2012, 06:20 AM
