549,877 active members*
2,215 visitors online*
Results 1 to 11 of 11
    Feb 2005
    154
    128 ps alarm ??
    Could someone tell me what a 128 ps alarm is on a Fanuc OM-d control ?
    It must be some sort of communications alarm. I got it working. Just wanted to know. I don't have it listed in my book.
    Thanks, Pete
    Community Moderator Al_The_Man's Avatar
    Dec 2003
    23820
    PS128 Illegal Macro Sequence No, macro ID not between 0 & 9999 , cannot be searched.
    Al.
    Albert E.
    Feb 2005
    154
    I guess it wasn't a communications alarm.
    I fiddled around with the cables and restarted the program and it ran. That's why I thought it was a communications alarm. It must not of seen something at the very start of my program. It didn't even read the second line.
    Thanks again, Pete
    Feb 2011
    I had the same error today. I had the communications parameters wrong at the pc.
    Sep 2011
    3
    Re: 128 ps alarm ??
    HI DEAR
    NEED HELP SUM DAYS AGO MY PC BURN AFTER STORM . WE CHANGE PC NOW WE START SENDING NC FAIL TO CNC .CNC CANT WORK IN DNC MODE .SOME BODY TOLD US THE COMMUNICATION IC NO 75188 AND 75189 BURN . WE CHANGE THESE TWO NOW WE SEND PROGRAM TO CNC PS 128 ALARM CAME
    May 2016
    506
    Re: 128 ps alarm ??
    change your settings on your pc
    Sep 2011
    3
    Re: 128 ps alarm ??
    Quote Originally Posted by mbservice View Post
    dear sir
    what kind of sitting. we change bud rate stop bit xon xof and pairty butt nothing works
    May 2016
    506
    Re: 128 ps alarm ??
    Please post your program as there could be a problem with it ?
    It is not sending program correctly
    Does it work when you send a standard file eg not drip feed
    Mar 2007
    22
    Re: 128 ps alarm ??
    Quote Originally Posted by qamar View Post
    HI DEAR
    Did you find the problem? I'm having the same problem ps128 while dnc. Please advice..
    Thx
    Mar 2007
    22
    Re: 128 ps alarm ??
    DHYSTA 02:53 PM Today
    Finally DNC transfer is back to normal after replacing PC serial card..
    Jan 2022
    Re: 128 ps alarm ??
    Quote Originally Posted by DHYSTA View Post
    I got the same problem since 2 Months, I have changed Communication cables but failed, should I change PC?
  1. Replies: 26
    Last Post: 06-02-2020, 04:11 PM
  2. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  3. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  4. ALARM shuttle drawbar alarm haas
    By timmydabull in forum Haas Mills
    Last Post: 02-18-2013, 07:47 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
