547,444 active members*
1,539 visitors online*
    1500 x 1000 CNC Router, 1st CNC build
    Hi All
    Wanting to share my 1st router build and get some feedback if I'm going wrong with anything. Still a work in progress but will update as i progress. Hoping to achieve light aluminum machining.
    Nema 34 motors
    Hiwin 16mm ballscrews ( 16x10 on X/Y, 16x5 on the Z)
    Hiwin 15mm Guides all round
    Ethernet Smooth stepper control (Mach 4),
    2.2kw Water cooled spindle (ATC Spindle in the near future)
    Schneider atv320 2.2kW variable speed drive.
    SICK inductive limit switches on all axis,
    Leadshine Em882S stepper drivers ,
    1kw 62V SMPS X&Z drives
    1kw 72V Unregulated supply for Y Drives (on the Way)
    X/Z Gantry being redesigned and made at the moment.
    Cheers
    Scott
    Attached Thumbnails Attached Thumbnails 20210529_185808.jpg   20210529_185752 horiz.jpg   20210829_170352.jpg   20210810_205032.jpg
    Dec 2013
    5014
    Re: 1500 x 1000 CNC Router, 1st CNC build
    Nice Work! Looks really good. :cheers:
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2014
    733
    I like the steel web on the face of the gantry.
  1. 1500 x 1500 CNC router - advice sought
    By ledaero in forum T-Slot CNC building
    Last Post: 08-24-2014, 02:09 PM
  2. 1st build 2nd attempt at a CNC router
    By rpe in forum DIY CNC Router Table Machines
    Last Post: 01-20-2012, 09:47 PM
  3. cnc router 1000 x 1500 x 100 mm
    By nasos-kas in forum News Announcements
    Last Post: 07-17-2011, 05:31 PM
  4. Want to build my 1st CNC Router...
    By Xtr3me in forum DIY CNC Router Table Machines
    Last Post: 11-24-2008, 08:43 PM
  5. 1st cnc router build
    By ajl6549 in forum DIY CNC Router Table Machines
    Last Post: 11-02-2006, 06:47 PM
