554,132 active members*
3,589 visitors online*
Results 1 to 8 of 8
    Dec 2005
    476
    15M CRT to LCD conversion
    The Fanuc 15M CRT is pretty dim and burned in. Still works but I figured I'd replace it with an LCD for better clarity. I ordered one off ebay that said it was compatible will all 9" CRT screens. Of course I ordered the cheapest one ($170). It arrived today. Plugged it in and all I get is a flickering black screen. OSD works so I know the monitor works. If I unplug the honda connector the OSD is stable, with it connected it appears and disappears quickly due to the signal. So I get out a mirror and discover my CRT is a A61L-0001-0092 and the new LCD is marked A61L-0001-0093. Is there a frequency and/or cabling difference between the A61L-0001-0092 and A61L-0001-0093?
    Doing some investigation it appears the monitor I purchased is this one:
    FANUC A61L-0001-0093 LCD monitor
    It also appears that aiderry (the manufacturer) has a model specific to the 0092.
    FANUC A61L-0001-0092
    Rather than shipping it back to HK I might just swap the converter board if I can source one easily. Any ideas?
    Re: 15M CRT to LCD conversion
    The signal types of FANUC A61L-0001-0092 and FANUC A61L-0001-0093 are very different. For details, please refer to the promotion on our website.
    ELONGSHINE tech ltd are the CNC machine tool monitor replacement specialists - save up to 75% on O.E.M. prices. Fanuc, Siemens, Mitsubishi, Mazak, Magnetek, Toshiba, Hitachi, Heidenhain, HAAS, Yasnac & most other old EGA CGA MDA monitor.
    Fanuc control system 18-M,21-M, 0-C, 0iM-tb series, including the 0-TC and 0-MC controls, The monitor is a 9? amber mono monitor, dual frequency – allowing highlighting.
    https://en.elongshine.com/product-de...61l-0001-0093/
    FANUC A61L-0001-0092 LCD monitor
    https://en.elongshine.com/product-de...61l-0001-0092/
    FANUC A61L-0001-0074 LCD monitor
    https://en.elongshine.com/product-de...61l-0001-0074/
    FANUC A61L-0001-0094 LCD monitor
    https://en.elongshine.com/product-de...61l-0001-0094/
    we are the manufacturer, more info at Home - Elongshine Technology Limited
    Dec 2005
    476
    Quote Originally Posted by elongshine2019 View Post
    Thanks for the details. The return post was prohibitive. I'm still using the old CRT. I assumed the LCD panel is the same on each model with a different driver/controller. I was hoping to just purchase the driver board rather than replacing the entire unit.
    Sorry, our two solutions are very different ,cann't help you.
    Apr 2009
    1306
    We are working on a universal 9" crt replacement that eliminates the problem of needing different models.
    Feb 2012
    126
    Try these guys: https://www.ebay.com/itm/VGA-LCD-Con...r/162708327950
    and tell them what panel you have and what your signal specs from the the control. You will have to make up a cable and do a little research but I think it is doable. Is this a 15 A or is it a later control. I think you are right that the panels are basically the same.
    Smile Re: 15M CRT to LCD conversion
    Quote Originally Posted by regina View Post
    This universal VGA solution cannot be used in FANUC's old CRT display.
    we have FANUC A61L-0001-0092 LCD monitor can use A61L-0001-0093, A61L-0001-0092, A61L-0001-0076,A61L-0001-0086,A61L-0001-0072,Its price is slightly higher.
    Can be adjusted by OSD for different FANUC machines.
    Jul 2021
    5
    If you are facing any fault in your LCD and LED so you need to relax because We provide LCD/LED TV Repairing services at your doorstep with your suitable day and time with no extra cost. you can visit this site for more information: http://bright-build.com/
  1. CNC conversion
    By cmurrayis in forum RF-45 Clone Mill
    Last Post: 08-13-2014, 10:05 AM
  2. STL conversion to V3D
    By tjskcnc in forum Vectric
    Last Post: 04-19-2011, 04:09 PM
  3. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
  4. Has any one done a CNC X1 conversion
    By cweeks in forum Benchtop Machines
    Last Post: 11-11-2006, 05:08 PM
  5. CNC Conversion?
    By muleworks in forum Bridgeport / Hardinge Mills
    Last Post: 07-14-2005, 06:15 AM
