Originally Posted by
joeavaerage
high speed...low speed means what exactly?
It really refers to the surface speed, that is to say the speed that a cutting tooth is forced through the material being cut.
Each material has its own properties and each tool has its own properties as well.
As a rule of thumb with a coated carbide tool in mild steel the surface speed should be 100 m/min.
Tough steels like 300 series stainless that reduces to 75m/min.
Titanium and Super alloys it reduces further to 40-50 m/min.
Aluminum can be cut with uncoated carbide tools at 250m/min and if you have di-boride coated carbide that can be pushed out to
500m/min. Copper cuts nicley with uncoated tools at 150-250m/min.
If you use HSS tools then all of the numbers above should be reduced by nearly a half.
Whether you use HSS or carbide, coated or otherwise they all cost. You really should try to get the best from them.
If you run them too fast, lets say you have a really highspeed spindle and you decide to run at 200m/min in steel you'll
turn the tip of the tool red hot within seconds and the tool will be wrecked and no cutting done. It doesn't matter that you take light cuts
it the SURFACE SPEED that determines the rate of heat generated, if you try to go too fast you'll fry the tool. If you try it
in aluminum you'll get 'built up edge' (BUE) and that wrecks the tool and the surface of the job too.
Much of the research into cutting tools and coatings is to increase the surface speed at which a given tool can be used in a particular
material. For instance I would reduce the surface speed to 85m/min with uncoated carbide in ordinary mild steel whereas I would run at
100m/min if the tool were coated. If the steel were free cutting and/or the tool geometry is such that the heat of cutting is carried away with
the chips then you might be able to push it out to 125 or even 150m/min. All of that is big potatoes to manufacturers.
As for going slower, yes that can be done but the tool wear does not reduce linearly as well.
Lets say I get three hours life from a coated tool at 100m/min in steel. If I reduce rotational speed to 50 m/min does the tool last twice as long...
no it does not. It will last longer but for a given amount of material to be turned into chips the rate of tool wear is increased per kg of chips
at slower speeds.
As I posted earlier I use 0.4mm and 0.5mm two flute endmills for prototyping circuit boards. With careful depth control I endeavor to cut
the thin copper layer on top and as little of the underlying fiberglass as I can. I would like to cut at surface speed of 200m/min, but I can't.
Follow the calculation:
Tool diameter, D, =0.5mm
Tool circumference,TC= Pi x D =1.57mm or 0.00157m
To have a surface speed, S, of 200m/min requires:
Revolutions per minute, rpm,= S / TC
=200/0.00157
=127,300 rpm
My spindle can only do 24000 so I have to run the tool sub-optimally. An air bearing spindle that can do 125000 rpm is way out of my league.
OP wants to cut steel with a coated carbide tool so an surface speed of 100m/min is indicated:
D=1mm
TC=3.141mm or 0.00314m
R=100 / 0.00314
=31,850 rpm (please note this calculation is correct, my earlier post where I calculated 15,900 rpm is wrong, its one half of what it should be)
To OP, run your 1mm tool at the highest possible rpm you can, anything less is just wasting your tool life.
If OP wanted to use a 6mm tool (coated in mild steel):
D=6mm
TC=18.84mm=0.01885m
R=100 / 0.01885
=5300 rpm.
Note how sensitive the required rpm is to tool diameter.
number40Fan runs a 6mm tool at 16000 rpm in aluminum:
S= R X TC
= 16000 X 0.006 X PI
= 301m/min which is right in the sweet spot for aluminum, I prefer coolant at that speed but you can get away without it.
This highlights how required rpm is sensitive to the material being cut, soft metals like aluminum, copper and brass can all be cut at 200m/min plus.
Steels at 100 m/min. Stainless at 75m/min. Titanium at 50m/min.
Once you've done the calculation and established the best possible surface speed you can THEN consider the feed rate.
Small diameter tools are weak...they have a very small core and consequently are easy to break by being overloaded.
One strategy is to reduce the feed rate and therefore take very thin chips. This has a draw back, especially in work hardening materials
like stainless, and heaven forbid should you try it in pure nickel, that all that happens is you give the material 'a good rub' and work harden
the surface making it even harder for following teeth to cut.
The key here is to take a reasonable 'bite' at the material, with small tools 1% of tool diameter per revolution per tooth.
For OPs 1mm tool that is 0.01 x 1= 0.01mm, or with four flutes 0.04mm per revolution and at OPs max 10000rpm= 400mm/min
feed rate. That will avoid the problem of 'giving it a good rub' and work hardening the material but now you almost certainly will
overload the tool and so have to take shallow cuts.
Shallow cuts means that the tips of the tool does all the work and when they are blunt you have to throw the tool away despite the rest
of the flanks of the tool not having been touched. Its a compromise, you may reduce the feed rate a bit but take deeper cuts to
get a better result.
For instance when I cut heavy copper board, by heavy I mean a thick, even very thick, for circuit boards, layer of copper 0.42mm thick.
The first slotting pass I take only 0.21mm and get the next 0.21mm in the next pass. Because its a slotting toolpath I have the feed rate
set to only 240mm/min. Thereafter I have a 50% step over, so that is 0.25mm wide cut but full depth of 0.42mm and I take that at 420mm/min.
With coolant to flush away the chips out of the cutzone I can get 8-10 hours cutting from one 0.5mm tool. All in all I find that this fairly
aggressive cutting style is best, a tool should 'work for its living'......babying them seldom works, they seem to get blunt just as fast, and with small
tools it usually as a mistake in tooplath or handling/jogging that breaks them and that happens irrespective of whether you choose an aggressive
cutting plan or not.
Craig
