527,868 active members*
2,284 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > 20mm ballscrew mounting question.
    Oct 2014
    10
    Hello does anybody know the mounting hole distance for SFU 2005/2010 ballscrew using BK15/BF15 end supports ? Any info would be appreciated.
    Re: 20mm ballscrew mounting question.
    Not sure whether you are means the thread length,
    For 2005/2010 ball screw which with end machining for BK15/BF15,the standard end machining length for both is 78mm,that means if the total length is 1000mm,then the thread length between BK15/BF15 is 1000-76=924mm.
    Generally the supplier can make customize length production according your design.
  1. Ballscrew and mounting
    By zymurgy42 in forum Uncategorised WoodWorking Machines
    Last Post: 11-18-2013, 03:03 AM
  2. Mounting BK12/BF12 Ballscrew Supports
    By LeelooMinai in forum DIY CNC Router Table Machines
    Last Post: 03-25-2013, 06:47 PM
  3. X3 conversion - ballscrew mounting question
    By Neil_J in forum Benchtop Machines
    Last Post: 03-05-2008, 08:16 PM
  4. Super X3 conversion with 20mm Ballscrew?
    By Kosa in forum Syil Products
    Last Post: 03-27-2007, 02:00 AM
  5. Ballscrew mounting
    By m_c in forum Linear and Rotary Motion
    Last Post: 03-11-2006, 10:51 PM
