I'm trying to configure Planet CNC MK3/4 controller with my stepping motor driver, I want to connect it through given 26 pin IDC cable but looks like there are little differences between both. followings are pin definition for my Stepper driver can you please advise if i can still use IDC cable? or if i can alter some pins, picture of controller is also attached.
1?25 pin parallel port control is defined as follows:
PIN1? CKE E axis pulse
PIN2? CKA A axis pulse
PIN3? CWA A axis direction
PIN4? CKB B axis pulse
PIN5? CWB B axis direction
PIN6? CKC C axis pulse
PIN7? CWC C axis direction
PIN8? empty
PIN9? empty
PIN10? DIN1 limit 1
PIN11? DIN2 limit 2
PIN12? DIN3 limit 3
PIN13? DIN4 limit 4
PIN14? CWE E axis direction
PIN15? E-Stop
PIN16? EN All axis enable
PIN17? RLY Relay control
PIN18~25? GND to ground
