552,801 active members*
2,081 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > 3000 CNC will not cut completly through Duraplate
Results 1 to 6 of 6
    Jun 2022
    My employer has aquired a used Multicam 3000 CNC.
    We are attempting to use it to cut panels out of Duraplate. The plate is just under 1/4" thickness.
    Galvanized steel .0160" sheet on each side with a composite core of .2042" inside.
    Our panels are created from Autodesk Inventor file masters, and saved as .dxf files.
    We then are using EnRoute software to create files for the CNC. All the information needed for the router is saved to each file.
    Spoilboard surface (has been fly cut) is good. Table vacuum is good. Panel is on the table and ready to go.
    We connect a wired calibrating 'puck' to the CNC. Surface is set. Max depth is set. File is selected and and then run.
    An EMC601604 1/4" carbide four flute endmill bit is used.
    Cuts through first steel layer and through the core, but it will NOT cut through completely on the second steel layer.
    We have to stop and increase depth incrementally through the control pad too many times.
    Then eventually it will cut through, but then into the spoilboard.
    Something somewhere is not calibrating correctly.
    Is there data setting cached in the CNC's drive we're not aware of holding it up?
    Calibrating puck defective?
    Dec 2013
    5560
    Re: 3000 CNC will not cut completly through Duraplate
    Check the difference in height between the puck and the spoil board. You may need to do some calibration. Or just 0 off of the spoil board.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2004
    5522
    You might be losing steps on the plunge. Are you ramping into it, or just moving the tool straight down? That's hard for most endmills, especially when they're trying to cut something hard like steel. Check your Z zero after the run, and see if it's the same as at the beginning. Another thing to try might be a drill-pointed endmill, which has an easier time poking through things than the typical center-cutting tool.
    Andrew Werby
    Website
    Jun 2005
    1561
    Cutting steel on a Multicam might be a challenge. What speed and feed are you running? Most spindles on these type machines is 8K to 24K which is pretty fast for steel, the carbide endmill can cut steel no issue there
    Dec 2005
    476
    Quote Originally Posted by awerby View Post
    +1 on losing steps. Check the Z axis screw is clean and lubricated. I've had similar issues on my 4000. It's typically time to clean and lubricate when steps are lost and/or my speeds and feeds are simply too optimistic.
    Sep 2006
    113
    Mulitcam's are known for weak Z's. As mentioned above, ramping EM's is important.
  1. Can a cnc router cut as fine inlays in wood and cut veneer for the inlay
    By videorov in forum Uncategorised WoodWorking Machines
    Last Post: 05-22-2017, 11:32 PM
  2. Replies: 3
    Last Post: 04-10-2015, 04:42 PM
  3. Emco 5 cnc lathe turret not rotating completly
    By rpace in forum EMCO Lathe
    Last Post: 06-03-2014, 02:02 PM
  4. Circle not cutting completly
    By hduke47 in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 02-18-2008, 09:36 PM
  5. New User, completly satified
    By Smitty911 in forum Alibre Design
    Last Post: 10-09-2007, 11:39 PM
