567,394 active members*
3,386 visitors online*
    Sep 2003
    1464
    3D printing round parts out of round
    I printed a 54 tooth gear for my South Bend lathe so I could cut 16 threads per inch, put it on the lathe and it only rotated about an inch. Measured the gear and it was 0.015” out of round.
    If I had results like that from my CNC that would mean that the steps per inch were either off in the X or Y axis and I would set those to be correct and that’s it.
    How Does the 3D printer address an out of round which either the X or the Y steps per inch is not set right, how do I adjust the steps per inch in my 3 D printer
    My Printer: Maker Select Plus 3D Printer PN: 15711
    Thanks my old homemade CNC machine is still going strong.
    Hager
    Community Moderator
    Mar 2003
    35529
    Re: 3D printing round parts out of round
    First thing I'd do is print a calibration cube to make sure it's the steps/unit.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Milling features on round parts
    By dubby in forum BobCad-Cam
    Last Post: 09-03-2013, 05:11 AM
  2. Replies: 5
    Last Post: 04-16-2012, 09:25 AM
  3. Holding Round Parts for Concentric Milling?
    By toyranosaur in forum General MetalWork Discussion
    Last Post: 06-22-2010, 03:01 AM
  4. Round parts with holes on OD
    By CharlesM479 in forum Solidworks
    Last Post: 07-09-2007, 03:08 PM
  5. Out Of Round Lathe Parts
    By chipslinger in forum DNC Problems and Solutions
    Last Post: 10-30-2006, 04:11 AM
