601,127 active members*
2,630 visitors online*
    Aug 2009
    5
    3V AC stray Voltage
    Hello All,
    DIY Router ( DDCS 4.1 Controller )
    I'm the Final Stages of my Build, and Busy checking wiring of Control box, and I came across this strange Issue.
    I have 3 AC Sockets controlled by the Controller Mist / Flood AUX Outputs via 24V DC Relays.
    However when I energise the Contactor, the 220V indicator LEDs ( LA3, 5 & 6 on attached Schematic ) light up, even with the Relays not energised.
    When I measure the Voltage across the LED i get 3V AC - this is enough to light the LEDs.
    - Voltage across neutral to Field Ground is +- 1V ac
    - Voltage across Live to Field Ground is Zero
    Any Ideas how to resolve the Stray Voltage, Any Ideas?
    EDIT ** I thought I could add a 1M Resistor, to stop the led lighting at low voltage - but it has no effect i
    Aug 2009
    5
    Re: 3V AC stray Voltage
    OK on further investigation, the LEDs show a very dim light due to the 3V ac (stray voltage) , when the relays close the LEDs are Bright ( as expected)
    I have Noticed that when everything is powered up, there is an AC voltage of +- 8V between my 24V dc Positive and the Frame ground.
    Will keep looking .....
  1. Replies: 6
    Last Post: 01-07-2025, 01:08 AM
  2. Replies: 10
    Last Post: 06-16-2014, 10:02 PM
  3. Stray Cuts
    By Igloomason in forum CamBam
    Last Post: 11-23-2010, 09:48 AM
  4. Where can these stray dots/points be coming from....
    By HankMcSpank in forum Mastercam
    Last Post: 08-09-2009, 09:33 AM
  5. Stray lines in SheetCam?
    By Joe Petro in forum SheetCam
    Last Post: 10-28-2007, 05:28 AM
