589,390 active members*
7,564 visitors online*
    Oct 2019
    11
    4/5th axis zero reference
    Unsure how to set the zero reference on a tsudakoma TN-131, aif 2/5000,aiA 1000 pulsecoders. Servo CMR, N/M, Ref Counter is set correctly. Verified the bit status for reference/decel sensor for both tilt and rotate axis and also the overtravel limit switches and everything is triggering correctly.
    Setting 1815 APCx to 1 and APZ to 0 and power cycling causes the two axis to go into remove/detach mode which sets 0012.7 to 1 and 1005.7 to 1.
    Going through the QuickNC to set the origin will zero based on the trigger signal from the axis but won't be the true zero position. I can manually position to the B0 and C0 positions of the axis and set a grid shift to adjust to true zero position but I'm not sure this is the correct way to do this. Do I set the angle difference from the reference trigger with 1240?
    Any tips on how to set this right?
    Mar 2024
    53
    Re: 4/5th axis zero reference
    Quote Originally Posted by Mobius View Post
    Discuss with me at [email protected] (+918168294379)
  1. How to add a 5th axis driver to existing 4 axis machine?
    By Mason Dixon in forum DIY CNC Router Table Machines
    Last Post: 01-31-2021, 07:05 PM
  2. G0704 5th axis
    By outsider787 in forum Benchtop Machines
    Last Post: 12-14-2012, 01:04 AM
  3. 5th axis
    By andrew2 in forum Tormach Personal CNC Mill
    Last Post: 01-01-2012, 05:21 PM
  4. 4th and 5th axis
    By --Speedy-- in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-20-2011, 03:17 PM
  5. Replies: 8
    Last Post: 10-29-2009, 02:09 PM
