540,709 active members*
7,226 visitors online*
Results 1 to 12 of 12
    Aug 2011
    50
    4 axis machining problems
    I was trying yesterday first 4 axis machining and things goes wrong, I checked the g-code online and it looks good there. Please see attached photo and g-code file.
    Link where I checked the g-code is https://ncviewer.com/
    I have MK1 controller from 2011 and never tested it on true 4 axis machining.
    Also X Y and Z colors are wrong in software, and the tool path is reversed on Y axis that is my rotary axis on.
Name:	cnc usb controller.jpg
    And should be like this:
    Moderator
    Mar 2017
    801
    Re: 4 axis machining problems
    Apart from G40.1 g-code (which is used for C axes on some Fanucs) .and incorrect toolchange in beginning I don't see anything wrong. NCviewer displays this incorrectly
    Aug 2011
    50
    I removed what was wrong for you, the problem is the deviation from the tool path marked in red on the picture, I ran this code and it broke my part exactly as it looks in CNC USB Controller, but in NCViewer tool path it is exactly as it should be. I have attached the modified tool path to check it.
    Second, in all CAM CAD programs the X axis is red and the Y axis is green.
    Third, the tool path does not look the same in the nc viewer with CNC USB Controller as an orientation.
    Attachment 443588
    Attachment 443590
    Aug 2011
    50
    Found the problem, B axis in machine definition was on Y+, changed that to Y- as it is on my machine placed, tool path is good, orientation also good, but god still X axis must be RED and Y axis GREEN.
    Best Regards
    Attachment 443600
    Moderator
    Mar 2017
    801
    Aug 2011
    50
    Exactly as I said X RED and Y GREEN, in CNC USB Controller software the X is green and Y red as you can see in pictures bellow.
    Moderator
    Mar 2017
    801
    Seems that old software used these color. I never noticed they are not correct.
    Why don't you use TNG?
    Aug 2011
    50
    Because I have a DIY Controller MK1
    Aug 2011
    50
    Quote Originally Posted by adidoro View Post
    Best Regards
    Attachment 443600
    How the hell I do that, I have the same problem with TNG now.
    Aug 2011
    50
    I think is only a display problem related to this https://www.cnczone.com/forums/plane...y-problem.html
    Waiting for an answer and a solution to that thread to compare, I don`t have nerve to run that program on my cnc.
    Moderator
    Mar 2017
    801
    Seems like you don't have correct orientation.
    Good explanation is here:
    https://www.autodesk.com/products/fu...tem-made-easy/
    Aug 2011
    50
    I already know that, please check this thread https://www.cnczone.com/forums/plane...y-problem.html
  1. Replies: 14
    Last Post: 01-06-2019, 11:08 PM
  2. Bobcad version for 4th axis true 4th axis machining?
    By Tormachmaster in forum BobCad-Cam
    Last Post: 12-18-2015, 01:37 AM
  3. Replies: 1
    Last Post: 03-09-2014, 01:36 AM
  4. Replies: 0
    Last Post: 10-24-2013, 04:49 PM
  5. Flow 5 Axis Machining on X-Axis
    By pvmachine in forum Mastercam
    Last Post: 09-20-2012, 08:29 AM
