Recently added a PCNC440 to our machines with a Tormach PDB. As you may know the control button for this version of the PDB is a pneumatic push button valve. Not electrical as on the 1100. I would like to add a foot control which would make tool changes much easier by freeing both hands. Is there anyone out there that has done this and what can you share about your design? I am thinking a foot switch powering a solenoid valve that would open an air valve, that operates the PDB. In addition I am thinking of adding a safety lockout that would disable the foot switch if the motor is running. Anyone know of a control signal already in the 440 control box area that in either on/off only when the spindle motor is turned on?
