585,752 active members*
4,160 visitors online*
    Mar 2005
    271
    4x4 CNC Router build. 45hsr rails?
    I got a really good deal on 2 hsr45 rails with 2 bearings for each. I'm thinking about using them for my cnc router build , do you guys think this is a bad idea, they won't be used on the moving gantry only on the frame part.
    Any input would be greatly appreciated.
    Thanks Mike
    Jan 2008
    1528
    Re: 4x4 CNC Router build. 45hsr rails?
    They may have more friction / require more motor torque. Depends partly on the preload.
    I would happily use them for a router.
    (I would go and pay lots of $$ as they are overkill but you already said you got them cheap)
  1. Placement of the Y Axis Rails for a plywood torsion box router build
    By QLDSteve in forum DIY CNC Router Table Machines
    Last Post: 10-27-2020, 11:03 AM
  2. How to limit dust build-up on rails?
    By rlrhett in forum Avid CNC
    Last Post: 04-15-2014, 01:03 PM
  3. Re-Build - Joe's Hybrid with R&P and Linear Rails
    By madtownrob in forum DIY CNC Router Table Machines
    Last Post: 04-23-2010, 08:57 PM
  4. Using Igus rails for 2nd build
    By jhowelb in forum DIY CNC Router Table Machines
    Last Post: 10-09-2009, 05:50 PM
  5. build help on alignment of leadscrew, rails etc
    By posix in forum DIY CNC Router Table Machines
    Last Post: 02-10-2006, 09:14 PM
