548,681 active members*
2,499 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > 5020L monitor Replacement Option??
    Feb 2021
    36
    I have a 1990 LB15 with a 5020L monitor that finally went on the fritz.. Looking to see if there is any new options available out there. CRT is the only thing that's on the fritz. Data shows but very faint and shows tracer lines on the screen when I control the brightness adjustment in the back. Looking for options??? Also does anybody have the wiring diagrams for a Okuma 5020L control?? Last question.... Does anybody have an option to mount a monitor outside the control with wiring specs.. If that's an option at all????
    Apr 2009
    1169
    Re: 5020L monitor Replacement Option??
    You can either repair that one or replace it with a flat screen monitor.
    Try these guys:
    Invision
    Richard Dankert
    (262) 521-2000
    Best regards,
    Experience is what you get just after you needed it.
    Feb 2021
    36
    Thanks for the info... I will let you know how it turns out...
  1. Another keyboard and monitor mount option...
    By David Bord in forum Tormach Slant Lathe
    Last Post: 09-23-2016, 10:56 PM
  2. Monitor replacement?
    By civilseal in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2015, 09:50 AM
  3. 5020L...cycle start button...replacement brand?
    By Voss_Machine in forum Okuma
    Last Post: 12-13-2013, 06:31 PM
  4. osp 5020L monitor went out!!
    By guydrisc in forum Okuma
    Last Post: 08-25-2011, 09:49 PM
  5. M32 Program Monitor Option
    By gasto in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-30-2006, 01:44 PM
