549,886 active members*
2,350 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > AEON Laser > 6 Factors you Must Know before buying a laser engraving and cutting machine- aeonlase
Results 1 to 1 of 1
    Sep 2021
    Making decisions is always very difficult. When you want to buy something you don’t know and must spend a large sum of money, it is more difficult. Well, choosing a laser engraving and cutting machine is even harder. Here are 6 factors you must know before buying a laser engraving and cutting machine.
    1. The working size you needed - 6 factors you must know before buying a laser engraving and cutting machine
    Laser engraver or cutter got different sizes. Typical working areas are:300*200mm/400mm*300mm/500*300mm/600*400mm/700*500mm/900*600mm/1000*700mm/1200*900mm/1300*900mm/1600*1000mm.Normally, if you told the seller, 5030/7050/9060/1390 etc, they’ll know what size you needed. The working size you needed is decided by the material size you are going to cut or engrave. Measure the materials you mostly work with, and remember, you never go wrong with a bigger size.
    working area
    2. Laser Power you needed - 6 factors you must know before buying a laser engraving and cutting machine
    It refers to laser tube power. The laser tube is the core of a laser machine. Typical laser powers are 40W/50W/60W/80W/90W/100W/130W/150W. It depends on what materials you want to cut and what is the thickness of your material. Also, depends on the speed you want to cut. If you want to cut faster on the same thickness materials, higher power will help you to realize that. Normally, the small-sized machine will install only smaller power tubes, as the laser tube must be a certain length to get to a certain power. If it is too short, it can’t reach a higher power. If you are not sure how much laser power you needed, you could tell the seller the material name and thickness, they’ll recommend you the suitable ones.
    3. Space you have to place the machine - 6 factors you must know before buying a laser engraving and cutting machine
    If you have much space to accommodate the laser engraving and cutting machine, always get a bigger one, you’ll soon be addicted to the machine and want to do some bigger projects. You could first get a dimension of the machine you are going to buy and measure the space where you want to install the machine. Don’t trust photos, the machine can be big when you see it in real.
    Please make sure to get the machines' size, Length, width, and height.
    AEON Laser offers desktop machines and commercial-grade machines.
    Desktop co2 laser engraving and cutting machine - MIRA series
    AEON MIRA laser provides maximum speed up to 1200mm/s, 5G acceleration
    *Smart compact design. Chiller, air assist, blower are all built-in. Quite a space-efficient.
    *Class 1 laser product level. Safer than others.
    * Free maintenance "CleanPack" technology. Reduces motion systems maintenance by at least 80%
    4. Budget - 6 factors you must know before buying a laser engraving and cutting machine
    Of course, how much money you are planning to spend is very important. Depends on what grade of machines you want. There are cheap machine prices from 300usd to 50000usd. Money always counts.
    5. Projects you would like to do - 6 factors you must know before buying a laser engraving and cutting machine
    If you want to cut more, you need a higher power and big size laser, the moving speed will not be so important. If you engrave more, the speed of the machine will be more important. Of course, people always want to get jobs are done faster, which means time and money. There are also machines that took care of both engraving and cutting, Like AEON Laser MIRA and NOVA machines.
    6. Business or hobby - 6 factors you must know before buying a laser engraving and cutting machine
    If you just want to learn something and as a hobby machine, get a cheap Chinese K40. This will be a good teacher for you. But be prepared to also learn how to fix it, LOL. If you want to do business, buy a commercial brand machine, choose a good reputable seller that offers superb aftersales service. AEON Laser provides all kinds of CO2 laser engraving and cutting machines from hobby to commercial-grade machines in high quality. Check with their salesperson or distributor, you’ll never go wrong.
    Lastly, A laser is a fascinating power tool for your business or job, and it is also dangerous, safety is always important. It is easily catching fire or gets burnt. Radiation and toxic gas also can’t be overlooked.
    Be sure to consider the machine you choose got enough safety devices, and consider where you are going to exhaust the toxic gas is made. If necessary, buy a fume extractor with it.
    AEON offers the professional Security
    1. The main power switch is key lock type, which prevents the machine from those unauthorized persons operating the machine.
    2. Emergency Botton (In case of any emergency, just press the button then the machine will stop working.)
    These are the 6 Factors you Must Know before buying a laser engraving and cutting machine. AEON Laser offers kinds of high-quality co2 laser engraving and cutting machines from hobby to commercial-grade, in faster speed, best after-sales service. According to the buying guide to picking the perfect one for your need.
    AEON MIRA laser provides maximum speed up to 1200mm/s 5G acceleration, Super NOVA is even faster 2000mm/s 5G speed acceleration!
    *Smart compact design. Chiller, air assist, blower are all built-in. Quite space efficient.
    AEON MIRA laser: https://www.aeonlaser.net/products/mira/
    Super NOVA: https://www.aeonlaser.net/nova-super/
    Apr 2004
    5433
    Re: 6 Factors you Must Know before buying a laser engraving and cutting machine- aeon
    It seems like the most important thing to consider is what material you're intending to cut, or engrave, something that didn't seem to make it into your "6 factors".
    Andrew Werby
    Website
