594,860 active members*
5,566 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > 6040 CNC Linear Guide Rails Upgrade
    Jan 2024
    21
    I would like to replace original linear guides and carriages (cheap and flimsy) with Igus TS-01-25 linear guides (https://www.igus.eu/product/drylin_TS_01?artnr=TS-01-25) and drylin® T guide carriage TW-12.
    Total height of assembly (carriage + guide) is app. 36 mm. Is this reasonable and functional solution?
    Nov 2013
    4961
    Re: 6040 CNC Linear Guide Rails Upgrade
    those rails you have linked to are aluminum......are you sure that solution will last long enough to justify the cost?
    All the better machines use steel rails, and I'm sure you've seen plenty, so what make you think aluminum is better?
    Craig
  1. Ballscrew position in between linear guide rails
    By sh2005 in forum Linear and Rotary Motion
    Last Post: 06-19-2020, 10:00 PM
  2. Step by step guide to upgrade an Omni 6040 CNC to a G540
    By Philbali in forum Chinese Machines
    Last Post: 11-02-2017, 02:43 PM
  3. Looking for linear guide rails for LRX45 or HSR45
    By skyguynca in forum Want To Buy...Need help!
    Last Post: 11-27-2015, 08:46 AM
  4. HiWin Linear Guide Rails Question
    By hive8 in forum Benchtop Machines
    Last Post: 12-25-2014, 02:59 AM
  5. Linear Guide Rails - Where to purchase?
    By Shrimp in forum Linear and Rotary Motion
    Last Post: 05-22-2013, 01:33 AM
