Hi Everyone, This is the Model CNC 6040 220v-380v PRT-E1500W controller VFD Manual translated to English,
Its the best I can do without redoing the entire manual.
Good luck
ENJOY
CHIMERA1960
Good luck
ENJOY
CHIMERA1960
Hi Everyone, I just wanted to add this manual also applies to the 110v version 6040 cnc machine, so you can use these VFD settings to setup your spindle motor. Also use the rpm display on your panel to show actual spindle rpm, because all cutting speeds are formulated for rpms anyway so you can set the correct speed of the spindle for the material.
I hope this helps take care later CHIMERA1960
CHIMERA1960
6040 cnc PRT-E1500W vfd settings.
Hi all, I have Connected everything like it should installed Mach3 and put on the CNC openend the Mach3 software it says driver loaded but nothing works or responds.
I did set the config as it should (double checked), still nothing.........
No drivers cd or Manual was given, took a lot of searching the internet too find anything like plugins but non worked for me.
Can someoone please help me i really want too enjoy my CNC. ( USB ) CNCEST PRT-E1500W
HERE MY VIDEO wish get some help.
- - - Updated - - -
https://www.youtube.com/watch?v=9F74wMPTkWM
CAN YOU HELP ME WHY MY CNC MACHINE NEVER MOVE?
