600,838 active members*
3,483 visitors online*
Page 1 of 7 123
Results 1 to 20 of 135
    Jul 2016
    19
    Question 6040 cnc PRT-E1500W vfd settings.
    Recently I bought a 6040 4 axis cnc router off of eBay and the instructions didnt have the right settings for the vfd that came with it.What should I do. I attached the manual to the thread THANKS.
    Jan 2005
    15362
    Re: 6040 cnc PRT-E1500W vfd settings.
    koolkleptokidd
    A lot have been having this same problem, you need the manual for the VFD drive then you will be able to set the VFD
    Mactec54
    Jul 2016
    19
    koolkleptokidd
    Do you know how i can find it? Ive looked all over the Internet and cant find anything on it.
    Apr 2013
    1915
    Quote Originally Posted by koolkleptokidd View Post
    Did you check the whole contents of the DVD? If not there you should ask the seller. If you can't get the manual from the seller you should give negative feedback and demand some refund or send it back. It is horrible that those people keep selling these products without even a crappy simple manual.
    Jul 2016
    19
    yeah, ive checked it multiple times and cant find anything, I attached the manual if you want to read it.
    Jan 2005
    15362
    I do have the VFD manual for this VFD, and I'm translating it now, so once I have it done, I will post the Parameter Settings, this will take me some time to complete, as some of it does not translate that well
    Mactec54
    Jul 2016
    19
    Thanks for your help, i appreciate it
    Apr 2013
    1915
    I have already checked what you posted, but that's not the VFD manual, it is just a bunch of pointless images with very little information. I mean the REAL manual. Why not ask the seller? Did you try that as well?
    Jan 2005
    15362
    koolkleptokidd
    This will get you started, there will be other adjustments needed, what size spindle motor do you have 800w or 1.5Kw
    D000=400
    D001=1 ( May be D000=0 by Default this will lock any Parameter Change )
    D002=400
    D003=400
    D004=220
    D009=400
    D010=100
    D011=10 ( Default=10 Adjustable Acceleration )
    D012=10 ( Default=10 Adjustable Deceleration )
    D031=0 ( Default=0 For Keypad use (1 ) for Remote Control )
    (D031 May need to be set to 4 D031=4 Depending how your Control is being used)
    D032=0 (Default May need to be set to 1 D032=1 Depending how your control is being used )
    D033=0 ( For Keypad Stop ( 1 ) If Remote Control is being used )
    D036=1
    Mactec54
    Jul 2016
    19
    I have the 1500w spindle motor.
    Mactec54
    Jul 2016
    19
    i've tried asking them before but all they do is keep sending the same manual to me.
    Jan 2005
    15362
    Mactec54
    Try the setting I have posted, they should get you going, we may have to adjust some others as well, the D001=1 has to be set first before you set any other parameters
    Mactec54
    Jan 2005
    15362
    They make this VFD, and don't have a very good manual, if you had it you would not be able to understand it anyway, I will work with you to get it running
    Mactec54
    Jul 2016
    19
    Ive tried the settings and I cant get it to work, is there a difference between if it has the 800w of 1.5kw spindle?
    Jan 2005
    15362
    No only the amp settings which I never found, now if you have the main Parameter settings in place, then there will be some control things we can try, Does the VFD power up ok can you do some photos, have you opened the cabinet
    What setting did you use in D031
    D032
    D033
    Try them all at 0
    Mactec54
    Jul 2016
    19
    D032
    D033
    Try them all at 0
    ive tried them all and it turns on the spindle but it only stays at 144.6
  17. #17
    Jan 2005
    15362
    Don't run it at that speed for very long only just to try the speed, this could damage the spindle
    Do you have all the Parameters I posted these must all be in place before running
    Have you switched the Spindle Mode Switch set to Manual on the front of the control Panel
    Mactec54
  18. #18
    Jul 2016
    19
    I did put all the settings in place and I changed it to manual.
  19. #19
    Jan 2005
    15362
    Another 2 to try just do 1 at a time and try it, it could be just one Parameter some where I will keep looking there may be something I missed, the manual I have is in Chinese and it has not translated very well
    Change D036=0 to Zero also
    D020=400
    D040=100
    Is your power supply 120v or 240v
    Mactec54
  20. #20
    Jul 2016
    19
    D020=400
    D040=100
    Its 120v
Page 1 of 7 123
  1. 6040 cnc PRT-E1500W vfd problem
    By koolkleptokidd in forum Spindles / VFD
    Last Post: 03-17-2025, 07:32 PM
  2. 6040 CNC VFD settings?
    By RoddQLD in forum News Announcements
    Last Post: 05-18-2019, 01:00 AM
  3. New 6040 CNC machine. Spindle controller settings.
    By RoddQLD in forum Australia, New Zealand Club House
    Last Post: 05-29-2018, 08:29 AM
  4. yoocnc 6040 s80 settings
    By RABBIDUS in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2013, 08:32 PM
