584,812 active members*
5,395 visitors online*
Results 1 to 6 of 6
    60hz question .
    Hello friends.
    I've the opportunity to aquire a 2006 cnc vertical machine center wich is wired to 220v 60hz and 40kva.
    In my country we run 220v 50hz.
    How it could affect the machine electronics or motors?
    It is possible to find a converter from 60hz to 50hz?
    Thank you in advance.
    Enviado desde mi GT-I9500 mediante Tapatalk
    Dec 2003
    24216
    Re: 60hz question .
    Any induction motors ran directly on line will run proportionally slower, otherwise you normally do not see that much difference, some have a concern about the motor inductance on 50Hz, I have never seen a problem.
    If you have a spindle controller or VFD then it can be ran at usual rpm.
    Max.
    Albert E.
    Re: 60hz question .
    OK. Thank you. I will look for a VDF.
    Jan 2005
    15362
    Re: 60hz question .
    Quote Originally Posted by EliseoMonteverd View Post
    I think you miss understood, the last Post, the machine will have a VFD spindle Drive so that part will be Ok, unless it has been custom made for that machine, you may have some other problems with electronics though, mostly things will run hotter, Check on the machine spec's most will say on the machine Tag 50/60Hz
    What is the machine Brand name, and where was it manufactured
    Mactec54
    Re: 60hz question .
    It is a Leadwell.
    Re: 60hz question .
    Maybe the spindle and electronics would run ok, or a bit hot. But water pump and chip conveyor Wil run a bit slow.
  1. 50 and 60HZ....
    By EliseoMonteverd in forum CNC Machine Related Electronics
    Last Post: 01-20-2017, 02:10 AM
  2. Which params to change on VFD for > 60Hz ?
    By bit pusher in forum Charter Oak Automation Support Forum
    Last Post: 01-30-2015, 01:19 PM
  3. Chinese engrave 220 50hz not 110 60hz
    By blairgr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-19-2012, 08:32 AM
  4. Operating the SHMS1325C on 60Hz power
    By Cabinet Man in forum Excitech routers
    Last Post: 09-15-2009, 10:07 AM
  5. Got a 60hz chiller instead 50hz need help
    By wickedboysap in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-18-2008, 06:28 AM
