529,979 active members*
3,435 visitors online*
Results 1 to 1 of 1
    8 series aluminum-lithium alloy
    Features and uses of each series of aluminum plates: 8 series aluminum-lithium alloy
    https://www.aluminumsuppiler.com/
    The 8 series aluminum plate is the aluminum-lithium alloy aluminum plate, and the main alloying element is lithium. Because lithium is the lightest metal in nature, adding lithium to the aluminum plate can effectively reduce the specific gravity of the aluminum plate while ensuring the strength of the aluminum plate. The 8-series aluminum-lithium alloy has many advantages and is a representative of high-end aluminum plates. Features of aluminum-lithium alloy:
    1. Lightweight. The biggest feature of aluminum-lithium alloy is its quality. The addition of lithium makes the mass of aluminum-lithium alloy lighter than most metals. As the content of lithium increases, its mass will further decrease. This feature has attracted many scientists to study it.
    2. High intensity. Aluminum-lithium alloy has high strength, its strength will not change significantly due to the increase of lithium element, and the strength of the alloy can be further improved by adding copper, magnesium, zinc and other elements.
    3. High rigidity. Aluminum-lithium alloy has high rigidity and strong resistance to deformation, and its rigidity will be further improved with the increase of lithium element.
    4. Anti-corrosion. Compared with pure aluminum, aluminum-lithium alloy has good corrosion resistance and strong environmental adaptability.
    5. Anti-fatigue. Metal fatigue is one of the main factors limiting the application range of aluminum plates, and aluminum-lithium alloys have excellent fatigue resistance and long service life.
    6. Good ductility. Aluminum-lithium alloy has good ductility, which effectively reduces the processing difficulty of aluminum-lithium alloy. Because aluminum-lithium alloys are mainly used in cutting-edge fields such as military, aerospace, and aerospace, and their production processes are regarded as confidential by various countries, although the performance of aluminum-lithium alloys is excellent, it is difficult to see the situation in the civilian field.
    Aviation applications of aluminum-lithium alloys: Aluminum-lithium alloys have been used or tried on military aircraft, civil airliners and helicopters, mainly for fuselage frames, flaps and ribs, vertical stabilizers, fairings, air inlet lips, Hatch, fuel tank, etc.
    Due to the low density and good performance of aluminum-lithium alloys, aluminum-lithium alloy structures are used in many aerospace vehicles. The aircraft manufactured by Lockheed Missile and Space Company (LMSC) uses low-density, medium-strength and high-rigidity materials, so a large number of aluminum-lithium alloy products are used.
    The domestic application of aluminum-lithium alloy: In the general civilian field, the representative brand of 8-series aluminum plate is 8011, which is mainly used to produce bottle caps. It is a typical bottle cap material and can also be used to produce aluminum foil, radiator fins, etc.
    Jul 2018
    1891
    Re: 8 series aluminum-lithium alloy
    Hello Ming and others - Typical Lithium alloys are 5-10% less dense then say 6000 series alloys and are about 5% stiffer. In general applications these differences do not matter. The alloys are also 3-5x more expensive which has hindered its general use. In applications like aerospace where weight is critical it has become a popular alloy in various situations.
    Lithium alloys suffer from corrosion quite easily. Lithium is a prime component of batteries and makes for an electrically unstable material. It also suffers from an interesting compression fatigue effect so is only used in areas of high tension such as the bottom skin of aircraft and one use parts such as rocker fuel tanks. Its been around since the 1920's and has steadily been improved. Regards Peter
