Dear Everybody
I'm new working with SIEMENS SINUMERIK 802C.
Can anybody help me how I can create "user-defined M function".
Dear Everybody
hj Friend.
Machine type defined by MD14510[16]. Lathe =0 (1) Milling =1 (2)
2. Define traverse keys according to your machine tool
MD14510[26] – X + key Lathe=23 (1) , (2)
MD14510[27] – X – key Lathe=29 (1) , (2)
MD14510[30] – Z + key Lathe=27 (1) , (2)
MD14510[31] – Z –Key Lathe=25 (1) , (2)
MD14510[28] – Y + key (if MD14510[16]=1) Milling = 24 (2)
MD14510[29] – Y - key (if MD14510[16]=1) Milling = 28 (2)
3. Define the inputs and outputs which are used as well as its wiring type (NO.NC) by
MD14512[0]&[1] for inputs of DIO1 if all active = FF (1)
MD14512[4]&[5] for outputs of DIO1 if all active = FF (1)
4. Define the functions you need by MD14512[11]:
Bit 7=1 Turret active for lathe
Bit 6=1 Spindle gear stage change active for milling machine
Bit 3=1 Spindle active
Bit 2=1 Clamping/unclamping active
Bit 1=1 Lubrication active
Bit 0=1 Cooling active
i think it's can help you.
Thank
Linh
