585,735 active members*
4,821 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 8ft x 8ft / 2,440mm x 2,440mm Cutting Area Router - Any Chinese Mfg That Produce?
    Nov 2007
    109
    We've purchased half a dozen CNC machines over the years directly out of China and are very familiar with the process of importing machines. We are now planning a move to sheets of plastic materials (lightweight HDPE, PP, etc) that are 8ft x 8ft in size (as opposed to 4x8) and we need CNC routers that can handle this size of material. We asked our regular supplier and they don't want to design such a machine and I'd like to know if there are any vendors or people that have had larger routers made and if so, do you have any references to those companies?
    Thanks,
    David
    Re: 8ft x 8ft / 2,440mm x 2,440mm Cutting Area Router - Any Chinese Mfg That Produce?
    whole cnc will have to be changeed 2 parts as continaer inside width 2300mm , at same time ,this type custom-design cnc need more cost than normal cnc.
    check OMNI 2600*7500mm working area cnc ,
    You can contact with me +8618560201508 [email protected]
  1. Where can buy long makerslide 8ft / 2400mm long
    By Shelby5041 in forum DIY CNC Router Table Machines
    Last Post: 05-19-2020, 04:22 AM
  2. 4ft x 8ft CNC Driver X & Y tables - need help!
    By RX7_LS7 in forum DIY CNC Router Table Machines
    Last Post: 10-10-2015, 04:56 PM
  3. Replies: 0
    Last Post: 04-19-2014, 08:46 PM
  4. Mfg. Engineer-Knoxville, TN area
    By jmjphillip in forum Employment Opportunity
    Last Post: 10-13-2008, 03:29 PM
  5. Panel saw that will cut 4ft x 8ft sheets
    By Router Lady in forum Want To Buy...Need help!
    Last Post: 09-18-2008, 05:09 AM
