527,819 active members*
2,176 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > A lot of deflection on belt driven CnC, better belts?
    Hey guys, I have a zenbot4896 Cnc router that uses belts as the drive system, well they are very flexible, and I don’t want to tension them anymore then they are because I’ve already broke a shaft off of one motor.
    Are there better, tougher belts that I could replace them with? I eventually play on converting to a rack and pinion setup, in just not there yet.
    Thanks in advance!
    Mar 2003
    35091
    Re: A lot of deflection on belt driven CnC, better belts?
    Yes, there are, but you still need to tension them a LOT, which will lead to more broken shafts. What you need are much larger belts, that likely won't even work without a redesign. I would say something at least 2" wide, although ideally it would be even wider. Belts will always stretch, and the longer they are, the more they stretch.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Belt Driven Z Axis
    By FreeRider in forum Momus Design CNC plans
    Last Post: 05-31-2017, 06:47 AM
  2. New CNC build with belt driven Z
    By n0rth3rnlight in forum DIY CNC Router Table Machines
    Last Post: 04-18-2015, 07:18 PM
  3. direct driven or belt driven
    By jeremy0203 in forum Benchtop Machines
    Last Post: 07-27-2011, 05:23 AM
  4. belt driven CNC
    By jwest in forum DIY CNC Router Table Machines
    Last Post: 11-29-2008, 11:10 PM
  5. Belt driven screw ?
    By tomcat47 in forum Linear and Rotary Motion
    Last Post: 01-29-2007, 05:20 PM
