Howdy all, Another issue with the 1996 sabre 1250 with the a2100.
The machine loads and all the diagnostics pass, the screen has no issues until you hit the green power button to turn the machine side power on, the screen begins loosing the display and flashing to a black screen. Visible horizontal interference "lines" slowly roll up the display, this only happens while the machine side power is on.
when you run a cycle the black screen gets even worse, to the point it is pretty much flashing black every second.
some days it is better then others, might only flash black 5 times on a good day.
The display is vga and comes directly from the WS board, the vga cable is in good shape.
the kti board also passes diagnostics and the touchscreen works (though It is had the fail light come on this board before)
It was originally a crt display and was changed out to a monitech lcd.
Any idea what could cause this?
