594,860 active members*
5,437 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > absolute Z value after applying a tool offset TNC 426/410
    Aug 2007
    230
    Hello, in TNC 426/410, how can I view the absolute value after applying a tool offset? There are three or four position values available, such as actual, reference, distance to go, etc. Unlike Fanuc or other controllers, which display a Z value of zero on the top surface of the workpiece after taking the tool offset, the TNC does not show the absolute value after the tool offset is applied. need to advise. I am using a cam generation software to get G-codes in iso format. please look sample program which is run sucessfully.
    %DRILLING_1 G71
    N1 G40 G90
    N2 G30 G17 X-100 Y-100 Z-75
    N3 G31 G90 X100 Y100 Z3
    N4 G17 T1 M6
    N5 S1000 M3
    N6 G00 X20 Y30
    N7 G00 Z20
    N8 G83 P01 2 P02 -20 PO3 -10 P04 0 PO5 80
    N9 G00 X20 Y30 M89
    N10 G00 X80 Y50 M99
    N11 M5
    N12 M30
    N999999 %DRILLING_1 G71
    regards
    asif
    Re: absolute Z value after applying a tool offset TNC 426/410
    this may help.
    https://content.heidenhain.de/doku/t...318_179-24.pdf
    Search for "Datum Setting" and "Workpiece datum"
  1. Replies: 1
    Last Post: 07-08-2023, 10:51 AM
  2. tnc 426 tool lenght
    By kumaloe in forum HEIDENHAIN -> TNC
    Last Post: 09-06-2011, 05:43 PM
  3. Thema: TNC 426, tool lenght and M30
    By saarman in forum HEIDENHAIN -> TNC
    Last Post: 08-25-2011, 03:31 PM
  4. Display Absolute on tool offset page
    By billm in forum Fanuc
    Last Post: 02-14-2007, 09:12 PM
