547,633 active members*
2,928 visitors online*
Results 1 to 5 of 5
    Hello
    I have several milling machines with Heidenhain controller.
    They are all connected via LAN .
    My question: Would it be possible to get operating data like current program status etc. onto the computer using LAN?
    My intention is to supervise the machine away from the actual machine position.
    Regards
    Studi
    May 2008
    547
    Yes that would interest me as well. Can you do that with a normal HH530 programming workplace??
    Administrator CNCFanatiker's Avatar
    Dec 2001
    5139
    Hello studi_pb
    Yes, it is possible! For example you can make simply screen shots of the TNC with a normal free of charge TNCRemo or set your own inquiry over TNCcmd command window or over Batch.
    In the extended range of functions, you can get it with ‘Live screen functionality ’- hence with real time screen transmission. It’s called TNCremoPlus but it’s no free of charge!
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
    Hello
    Regards
    Studi
    Aug 2021
    6
    Re: access controller and program using LAN
    Quote Originally Posted by CNCFanatiker View Post
    Hello studi_pb
    Hi CNCFanatiker, I am looking for manual/example of using tnccmd to extract information from Heidenhain controller, can you please share me the information if you have?
    Thank you.
