567,245 active members*
4,536 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Acramatic 2100 Realtime CPU Board BIOS
Results 1 to 11 of 11
    Jul 2017
    Does anyone have the files to flash the bios on the realtime cpu board? Part number is 3-424-2168A03. I have the hardware req'd to boot the board, just need the proper files. I replaced the battery that was soldered to the board with a battery socket to make changing it easier.
    Any help would be greatly appreciated!
    Thanks!
    Jun 2011
    5
    Re: Acramatic 2100 Realtime CPU Board BIOS
    Acramatic 2100 Realtime CPU Board BIOS from 1998.
    Nothing wrong with the DV5 card even if the alarm says so!
    Jun 2011
    5
    Acramatic 2100 Realtime CPU Board BIOS 1998
    Jun 2011
    5
    Acramatic 2100 Realtime CPU Board BIOS 1998.
    I tried until it worked. And this is the result for my machine. But not know if it is correct
    Dec 2006
    578
    What you have is the set up for the BIOS not the actual BIOS. I think it is dependent on the manufacturer if the RTC board that determines what BIOS is installed and the settings. Someone else may have more info on this or you could send the board back to SIEMENS or FIVES machine company to get it re-flashed.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Jun 2011
    5
    Quote Originally Posted by meckardt55 View Post
    The machine now works with the settings I've put on the pictures.
    The machine works as usual again without problems, Bioset was from 1998.
    Real-time board Item no. 3-424-2169A03. Returning if I find a problem arises. Wondering if it costs anything to get the card restored or is that free ??
    Aug 2017
    16
    Quote Originally Posted by olastj View Post
    hello, to connect the RT with AT source and ISA VGA card, some jumper positions are modified (jumpers on J pins)
    Hi guys please
    I have a Cincinati CNC machine ARROW 500, i have a problem with realtime cpu board part number is 3-424-2168A02 and error is NC Engine base failed.
    And i replaced the battery and i need the bios programming file and set up for the bios
    Many thanks
    Quote Originally Posted by confyone View Post
    Hi confyone,
    I need to hlep me please.
    How to satrup RT after connect with AT source and PCI VGA card, i need a pictures for jumper position and how to make start up RT board
    Attached Thumbnails Attached Thumbnails 15757166317271504636426306905298.jpg
    Hello Iheb , I have the same problem now , did you find the solution please ?
    I'm having the same problem
    Feb 2023
    Hello, I know this is an old post, but do you happen to know which jumpers need to be moved?
  1. acramatic 2100 bios help??
    By jerrybmiller3 in forum Cincinnati CNC
    Last Post: 10-26-2018, 05:26 PM
  2. acramatic 2100 bios help?!?!
    Last Post: 10-26-2018, 05:21 PM
  3. Replies: 4
    Last Post: 04-16-2017, 10:25 AM
  4. A2100 Realtime board BIOS help request
    By spumco in forum Cincinnati CNC
    Last Post: 03-01-2017, 09:38 PM
  5. Acramatic 2100 Realtime CPU Board BIOS
    By turbotadd in forum Cincinnati CNC
    Last Post: 01-28-2017, 04:42 PM
