600,786 active members*
3,227 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > ACRAMATIC 850SX MC CONTROL A/C RED TOP FANUC DRIVES- SPINDEL STOP ALERT
Results 1 to 5 of 5
    PROBLEM: AT ANY TIME THE SPINDEL IS COMMANDED TO STOP I GET ALERT CODE - 16730
    AFTER A DATA RESET I GET ALERT CODE 12479 IF I TRY AND RESTART SPINDLE OR A 15901 WHEN PERFORMING A TOOL CHANGE AFTER THE 16730 HAS SET.
    ONLY WAY AROUND THIS IS TO DO A FULL POWER DOWN REALIGN AND SO ON. EVERY TIME i NEED TO STOP THE SPINDLE
    THIS USED TO BE AN INTERMITTENT PROBLEM BUT NOW IT IS EVERY TIME IF THE SPINDLE SPEED IS ANYWHERE OVER LETS SAY 2000 RPM IF ITS UNDER THAT EVERYTHING WORKS AS IT SHOULD
    WHAT PART IS RESPONSIBLE FOR PUTTING ON THE BRAKES SO TO SPEAK IN THIS SITUATION? WOULD SWAPING A MAIN POWER INPUT PHASE AROUND POSSIBLY BE THE FIX?
    THANKS ANY HELP OR IDEAS MUCH APPRECIATED
    Mar 2008
    310
    Re: ACRAMATIC 850SX MC CONTROL A/C RED TOP FANUC DRIVES- SPINDEL STOP ALERT
    What fault code do you see on the Fanuc A06B-6959-C212 Spindle drive when this happens?
    I get an AL-02 code on the digital readout
    Mar 2008
    310
    Fanuc A06B-6959-C212 Spindle Drive
    Fanuc-Manual:
    Alarm 02 (AL-02) Excessive Speed Deviation
    Causes:
    Overload; such as mechanical binding
    transistor module is damaged,
    loose connections, to motor power
    error with speed feedback signal,
    blown fuse.
    Solution:
    Replace parts, check connections, review cutting conditions.
    The fact that it only happens during deceleration; but not during normal cycles may be orientation board related
    or loose wires.
    I would talk to Fanuc Tech Support
    Ill do that today and ill update with what transpires from there thanks
  1. Fanuc Red Cap 5S Replacement Drives
    By system24seven in forum Servo Motors / Drives
    Last Post: 04-22-2020, 02:47 PM
  2. Sabre 1000 - 850SX - won't align - 15144 alert
    By John-INTENSE in forum Cincinnati CNC
    Last Post: 03-12-2015, 08:15 PM
  3. Replies: 2
    Last Post: 10-13-2014, 04:24 PM
  4. 850SX ALERT NUMBER: 15345
    By bborb in forum Cincinnati CNC
    Last Post: 02-28-2013, 03:30 PM
  5. Acramatic 850SX to Fanuc / Haas Conversion Software
    By BlueChip in forum Cincinnati CNC
    Last Post: 03-08-2011, 08:31 PM
