548,308 active members*
1,206 visitors online*
    add stepper motor
    on my 3d printer i was able to piggyback a stepper on the z axis for better resolution. thets say you have a 3 axis board and need a dual steeper setup to control both sides of the gantry, can you do the same and run two longs as they didnt max the v/a?
    Nov 2008
    583
    Re: add stepper motor
    Not sure what two longs means but I recommend you search images for: wire two steppers serially
  1. Replies: 1
    Last Post: 03-07-2021, 04:40 AM
  2. Connect an 8 wire stepper motor to a TB6560 Stepper motor driver
    By muldoon22 in forum Stepper Motors / Drives
    Last Post: 12-31-2016, 07:26 AM
  3. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
