So I have a job coming up with high(er) accuracy than usual (needs +/- 0.001). I made some test pieces and they were all off by about 3-5 thou in various dimensions. Decided to go back to basics to get a baseline before trying any adjustments. I cut 5 "squares" out of aluminum with commanded size of 0.75". Cut path was a contour with helical descent, followed by a 0.005" full-depth cleanup pass. Photo attached.
Results are very consistent, so that's good. Along the top edge, in both dimensions, the size is 0.754-0.755. As you move deeper into the cut the size moves out to 0.758-0.759. I need to bring these down to 0.750-0.752.
It was leveled and trammed but otherwise unadjusted since installation about 4 years ago. Rarely need precision parts, so I don't have any records of accuracy back then. I know it's not backlash, since I regularly watch my Haimer during part setup and it's always around 0.001. The machine is due for a thorough maintenance anyway, so this seems like a good time to delve into the accuracy issues as well. Anyone have a punchlist for tracking this down?
Searching recent posts, this is what I have so far:
- Check gibs
- Check runout
- Check tram & level
- Check slideway racking
- Check twist in base
- Test cut an ID or OD circle, then check for out-of-roundness (from Keen's thread on accuracy)
- Just realized I should have put a fresh cutter in to eliminate cutter wear, but 0.0025" cutter wear seems implausible (3/8" 3fl HSS).
Thanks,
--Bryan
