Has anyone had the pleasure of opening a file used by an ADOBE ILLUSTRATOR PROGRAM...(ei file)it doesn't seem to come in right
Hi, I just found out how to make a jpg file in to a vektor file with closed clean and single "no bul****" vektor lines suitable for cnc machining / engraving or venyl cuting or what ever.
Import jpg to illustrator.
Mark the jpg, then go: Object > Image Trace > Make, then tweak settings as desired in image trace window/toolbar > Object > Image Trace > Expand, > In the Pathfinder toolbar hit Merge one time (or two times) then also in the Pathfinder toolbar hit the Outline button.
It should work to export it as pdf / dxf, or in my case just open it in Rhino3D as an .ai file.
Mabe you knew mage you didn’t. I didn’t. So I had to share it some ware
Bles you all.
Now You Can Easily Save Image to Any Format, Adobe Illustrator's Latest Version Support all types of formats.
Here is a list of 10 best laptops for adobe illustrator for running software like adobe illustrator without any lag. https://tenrater.com/best-laptops-fo...e-illustrator/
You could try renaming the .AI file to .PDF
PDF is the native format used by Illustrator.
But Illustrator also will export to .DXF which comes into most CAD programs.
And yes, years ago Adobe had a program called Streamline that allowed conversion of bit mapped images to vector format. But now its been incorporated into Illustrator.
Rod Webster
www.vehiclemods.net.au
Thread is 6 years old..... OP has probably upgraded the software .... or junked it
Superman......!!
Your list is great but I think, this guy has a great taste. https://bestlaptopempire.com/best-la...r-illustrator/
If you are searching for Best Laptops with Fingerprint Scanner And Touch Screen, then you are at the right place.
https://www.laptophop.com/best-lapto...print-scanner/
Are you searching for Best Budget Gaming Laptops Under 1200 USD Dollars? And you don’t know which laptop is best for you. Don’t worry; I am here to solve your problem.
https://www.laptophop.com/best-budge...ps-under-1200/
You can convert Image to Any Format with Adobe Illustrator's Latest Version. this version is lost data everytime so i recommended back up software. some backup softwares are avaiable here.
https://www.techrudraji.com/2021/03/...-business.html
