Can anyone help
I have just purchased this machine, six months old, all in good nick and seems fairly well built.
CNC 1212 Router [CNC1212] -
It uses a Leetra MPC6610 controller, a hand held device which accepts G-code via a USB stick and is connected to the breakout board via a 50 pin connector. User manual attached. Also a picture attached
This drive three steper motors via Leadshine M542 stepper motor driver cards. Manual attached.
I want to be able to use this machine via Mach 3. So my questions are;
I can get a cable that will go from the 50 pin connector, to a serial port connector. But, how do I know what all the pin assignments are to set up Mach 3? Has anyone converted one of these machines before? Are there any easy ways of figuring out what all the pin assignments are?
Or, can I buy a new breakout board that uses a standard serial port cable? If so, what kind and from where? And again, how do I know the pin assignments?
All advice appreciated.
Tom
