hello all
have you a solution for reinstall hard disk on agie 120
ghost image or disquette installation ??
my hard disk is dead
i have any idea for rebuild data and i found nothing on the web
thanks for your help or ideas
sorry for my english
bye
hello all
bye
hello
i progress to repair my hard drive
but have you a solution for this stage
checking security device ...
hard drive stop here
any solution ??
make a good day
Hello,
You found the solution to your problem of hard disk with AGIE 120.
I have the same problem.
I changed the hard drive, but the problem persists.
If you find information, I can help.
Thanks.
hello
no solution at this time
i start agie with an 260 mo hdd
but i'm blocking at this stage:
i don't no if it is software protection or other problem
i go to make test with 120 Mo hdd
original hdd on agie is 120 mo hard drive
with 4 partitions
c: 6 Mo
d: 40 Mo
e: 40 Mo
F: 28 Mo
have you a ghost image or other of your hdd ?? Sif369
to be continued
some help are more appreciable
bye
no other people have problem with agie hard drive ??
Hello!
I don't have a ghost image or other disk floppy.
I need to resolver the problem.
Do you have the 4 partitions?
Regards!
hello Sif369
please read your private message
thank
regards
hello
success !!
my fake agie hard disk running
agie 120 start with my 260 Mo hard drive with ghost image
how did you solve problem?, i also have a bad/dead HD, any help would be appreciated
hello
what is exactly your problem ??
agiematic CF boot on your hard drive ??
what message have you ??
regards
Hi steph
we have agie 150hss with a bad hard drive, error loading software, error initialize
Any help will be appreciated
my fake agie hard disk running![]()
Hi! A have idea how repare HDD for Agi 120
what problems have you excatly ??
models ?
hardware ?
trooble ?
Hi, I'm looking some missing files for my AGIECUT 220.
It seems the hard drive is not dead yet but the folder CU91 is missing.
Can someone provide some files or help ?
regards !
hello puggy
folder CU91 from working image at this link
CNCzone.com-The Largest Machinist Community on the net! Over 300,000 members and growing.
good luck
don(t forget
make scandisk on your agie hard drive
and copy CU91 folder from the archive
bye
Hi Steph !
Huge thanks to you.
My old Agie is running again.
Greetings![]()
