585,759 active members*
4,209 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Alarm 090 reference return FANUC W2 EDM
    Sep 2017
    4
    Hi all , I have this alarm in FANUC W2 EDM when I want will axes U to reference by manual or G28
    I check battery and those were changed .
    In manual about alarm 90 has told " the zero return can not be performed normally because the zero return start point is too close to zero point or the speed is too slowly "
    therefor do anybody have information and experience to related this problem .
    Oct 2020
    9
    Re: Alarm 090 reference return FANUC W2 EDM
    Honestly, the description of the problem is not clear enough to give proper advice, but I will try to find a solution for you.
    Oct 2020
    9
    It seems like you need to set the zero point correctly, and this should be specified in your manual. Honestly, the description of the problem is not clear enough to give proper advice. My understanding is that the error occurs during the execution of the C coordinate enable command. Specifically during the performance of the spindle orientation and the subsequent holding in that position to mechanically engage the gears. I have not encountered such a problem; I took a good car on credit, but the tax is hefty, unfortunately, but I know how to make a check stub online, so I will not be fooled. And I wish you to solve the problem as soon as possible.
  1. Fanuc Zero Reference Return Problems?
    By grege101 in forum Fanuc
    Last Post: 09-19-2023, 12:52 PM
  2. Fanuc 6m Manual reference return
    By Lomach in forum Fanuc
    Last Post: 08-28-2017, 01:15 AM
  3. fanuc 18i-m , alarm 90, reference return incomplete
    By azizcom83 in forum Daewoo/Doosan
    Last Post: 11-17-2016, 11:31 PM
  4. Alarm 090 Reference Return Incomplete
    By Don18P in forum Daewoo/Doosan
    Last Post: 08-22-2016, 07:59 PM
  5. Deco 10 swiss screw machine. return to reference point alarm 224 S1 spindle
    By Braingauge in forum CNC Swiss Screw Machines
    Last Post: 10-31-2013, 06:36 PM
