592,316 active members*
5,777 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Alarm 21 Power drive fault (1, 0, &0017) Mazatrol T plus
    Hello everyone!
    My SQT 15 Ms lathe has a problem while running.
    Can anyone guide me to fix it? I looked up the error "Alarm 21 Power drive fault (1, 0, &0017)" and it said "AD converter error"
    Please guide me if you can.
    Oct 2024
    7
    Re: Alarm 21 Power drive fault (1, 0, &0017) Mazatrol T plus
    Hi
    For the SQT 15 Ms lathe, the "Alarm 21 Power drive fault (1, 0, &0017)" related to an "AD converter error" typically indicates an issue with the lathe's control system, specifically with the analog-to-digital conversion process that interprets signals from various sensors or inputs. I would start by checking the wiring and the sensor inputs. I am sorry I do not have much experience with this specific brand and model, so I could not add more details to help.
    Nov 2012
    387
    Probably not wiring.... This is likely an actual chip level fault on the drive.... What type of amps do you have?
  1. Alarm 39-83 spindle drive fault
    By Muggins in forum Cincinnati CNC
    Last Post: 04-09-2019, 06:59 PM
  2. 21 Drive unit power malfunction 1,0,&0023 alarm
    By JOEC8 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-16-2014, 07:24 PM
  3. Alarm 123 DRIVE FAULT on startup.
    By DZANDF in forum Haas Mills
    Last Post: 04-14-2014, 01:25 AM
  4. Alarm 123 Spindle Drive Fault
    By Shotout in forum Haas Mills
    Last Post: 05-27-2007, 05:48 PM
