600,787 active members*
4,652 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > alarm turret 1000 turret conuter error
Results 1 to 4 of 4
    Nov 2010
    5
    dear friends ,
    I have problem with machine cnc turning fanuc OT, goodway GCL 2L & 3L
    when we turn on the machine every morning, then rotate the turret by pressing the index, go to the tooling turret number 1 ,
    then we turn again turret to the next position, the turret rotates continuously refused to stop. but when we try to turn off and turn ON the engine 1 or 2 hours later and the turret ok .
    but the problem arises again tomorrow morning.
    alarm operator message
    2031 turret No. 1 serch
    2057 turret clamp error
    before this alarm showing, the turret crash with spindle. the shaft turret crashes. we change shaft turret.
    please help my problem
    thanks
    andy, batam
    Quote Originally Posted by aaagt78 View Post
    dear friends ,
    thanks
    andy, batam
    We have the same problem right now. Have you found a solution for this issue? What is the problem? Can you help me? The machine name is Goodway GLC-2L.
    Mar 2025
    Re: alarm turret 1000 turret conuter error
    first turn off you machine then push @ the end and right side to take the zero and size of bed let me know what happen
    Mr.ren
    Top machinery
    Ajman United Arab Emirates
    Oct 2024
    dear friends ,
    alarm operator message level devil - not a troll game
    thanks
    andy, batam
    It sounds like the turret's position sensor or encoder might be misaligned or damaged after the crash. Try checking and recalibrating the turret position sensor.
  1. Replies: 26
    Last Post: 03-02-2023, 11:25 AM
  2. Clogged coolant between turret housing and turret
    By autotrol9 in forum Hyundai Kia
    Last Post: 07-10-2014, 10:40 AM
  3. HELP QT 350 alarm code 371 turret servo alarm
    By kirkmach in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-19-2011, 09:39 AM
  4. Tool Turret Fault Alarm on TL-1 with no Turret?
    By Edster in forum Haas Lathes
    Last Post: 02-08-2010, 03:35 PM
