544,084 active members*
2,321 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Alarm wiring on Rnr motion card (Red)
Results 1 to 4 of 4
    Dec 2015
    10
    Hi.
    I have 2 drivers HBS860H. I tried to connect alarm+ from one driver to the Input 1 of the controller, then Alarm- bridged with alarm+ on the other driver and A- to DCM (gnd for24V). I added a 24V power supply for the board. But if one driver goes in alarm the other just continues to work. Does anybody have the same issue?
    Jan 2018
    708
    Re: Alarm wiring on Rnr motion card (Red)
    Quote Originally Posted by trivalb View Post
    Hi.
    Why not just connect alarm into the estop circuit if you want them all to disable when one alarms?
    Dec 2015
    10
    Quote Originally Posted by dazp1976 View Post
    Thank u for reply. tomorrow I will try . Anytime I think I will go with cncdrive UC300eth and UCCNC cause this chinese board is not responsive in jog , not enought.
    Dec 2015
    10
    Ok, I changed board. Using a standard chinese 5 axis lpt and UC100 USB , I have wired all Alm+ together to estop. All Alm- to Gnd. It works properly. Please moderator should change the board in the title. Thanks
  1. 6040 router - wiring limit switches into USB Motion Card
    By redfoot in forum Chinese Machines
    Last Post: 01-14-2021, 12:08 AM
  2. RNR Mach3 Motion Control Card - MPG connection
    By CrazyJane in forum Mach Software (ArtSoft software)
    Last Post: 02-13-2019, 02:29 AM
  3. rnr motion breakoutboard
    By manumv in forum Controller Cards
    Last Post: 02-02-2019, 12:37 AM
