527,864 active members*
2,329 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Allen Bradley Ultra3000 and MPL servo
Results 1 to 5 of 5
    Sep 2011
    42
    I am stuck on trying to find out what is going on with this combo. I'm hooking up the servo drive and communications cable and getting a E11 error, which is "phasing not correct". This has happened on two separate motors and drives. I've checked the wiring many times. I've tried changing the orientation of UVW to see if I can get anything else. Nothing is getting me there. I should note that I'm a retired mechanical engineer so while familiar with servo drives I'm certainly no expert. Both drives and and servo's were purchased used but have checked out for shorts, continuity, and such. Does this setup require me utilize a program to set up the servo to remove the E11 error? Any help would be greatly appreciated.
    Thanks,
    John
    Aug 2009
    665
    Re: Allen Bradley Ultra3000 and MPL servo
    ...the encoder and feedback phase makes a difference too. right?
    Sep 2011
    42
    Yes it does. I've checked the voltage to the encoder and it's correct. I need to get my scope out and check the output next.
    John
    Jan 2009
    327
    Quote Originally Posted by jcsb View Post
    Thanks,
    John
    Hello JCSB
    These are not connect and run systems, they must be set and configured for the connected motor type.
    The manual: https://literature.rockwellautomatio...n005_-en-p.pdf
    You need the UltraWARE software at: https://compatibility.rockwellautoma...aspx?crumb=112
    See page 100 for: E11 Illegal Hall State.
    Verify the correct wiring of the hall phases for commutation and select the proper motor, see PAGE 21, this should correct the problem. Remember you have (UVW power stage) and (Hall sensor states for commutation).
    Hope this helps,
    Iron-Man
    Sep 2011
    42
    Thanks. I will try to resolve this tomorrow.
    John
  1. Replies: 0
    Last Post: 12-04-2018, 10:28 AM
  2. Allen Bradley ultra3000 drive/motor issue
    By chevydyl in forum Servo Motors / Drives
    Last Post: 08-28-2015, 12:08 AM
  3. Allen Bradley AC Servo Motors
    By Hydrodynamic in forum DIY CNC Router Table Machines
    Last Post: 05-16-2008, 04:00 PM
  4. Allen Bradley servo drive
    By efrem in forum Servo Motors / Drives
    Last Post: 07-06-2006, 04:07 AM
  5. Allen Bradley Servo spec help
    By CAM_MAN in forum Servo Motors / Drives
    Last Post: 02-24-2005, 06:00 AM
