537,582 active members*
3,759 visitors online*
IndustryArena Forum > MetalWorking > General MetalWork Discussion > Alternate use for abrasive chop saw?
Results 1 to 5 of 5
    Aug 2011
    149
    I am in the process of rearranging my metal workshop. One tool I am trying to decide if it should stay readily accessible or move to once in a while needed storage is my old 14" 3300RPM abrasive cutoff saw. At this point I only use it for cutting really nasty stuff I don't want to risk a band-saw blade on. I don't think I have used it in a year or more.
    I have several other ways to cut stock down to size. A 4x6 import bands saw and a plasma cutter serves the vast majority of my day to day stock cutting. I also have a 10" Delta chop saw I plan on putting a nonferrous metal cutting blade on for aluminum. These feed a mini mill, 10" Atlas lathe or welding projects.
    I vaguely remember seeing some one use one to good effect for sharpening cutting bits. I do have a 6" bench grinder and a belt sander for that. Any one have a, "why have I not known about this before?!?" kind of use? Could it be better at cutting relief into HSS lathe tools than a normal bench grinder? I could build a tool plat form for it if that's the case.
    May 2015
    566
    Re: Alternate use for abrasive chop saw?
    If you have a bandsaw, I can't think of any reason to own a chop saw unless like me you need to cut down rubber hose containing a metal spring to keep it open.
    So rubber hose is the only thing my chop saw has ever cut!
    Rod Webster
    www.vehiclemods.net.au
    Jan 2021
    11
    You could turn it into a cold cut saw. This guy is pretty insightful.
    This is a really good video of how's and why's turning a miter saw into a cold cut saw. I dont see why you couldn't do it with a fiber disk saw
    https://www.youtube.com/watch?v=gMVIdDKgG5A
    Aug 2011
    149
    I have seen that video, I don't see that replacing my other cutting methods. I was more thinking of sharpening or other things you would use a bench grinder for. I do remember seeing some one sharpen a drill bit or end mill with one, but I can't remember if that was because that's what was available or because it had some advantage I can't think of.
    Jan 2021
    11
    Quote Originally Posted by tjbaudio View Post
    I I do remember seeing some one sharpen a drill bit or end mill with one, but I can't remember if that was because that's what was available or because it had some advantage I can't think of.
    I agree with you. I can't think of a reason it would be better to use a chop saw.
  1. Metal Cutting Chop Saw vs Abrasive Chop Saw
    By diarmaid in forum Metal Working Tooling
    Last Post: 02-22-2021, 01:17 PM
  2. Opinions: wood chop-saw to metal chop-saw duty
    By soundmotor in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2009, 07:59 PM
  3. best basic chop saw
    By nc9933 in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2008, 09:10 PM
