575,312 active members*
2,318 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Alternative to Mitchell Electronics TI-5000
Results 1 to 12 of 12
    Oct 2017
    15
    Hi all I work at a repair shop and I'm looking to find an alternative for the mitchell TI-5000 encoder test system. The guys at mitchell have moved to a time based subscriber model (it used to be just a licence key and unlimited) and we don't see enough motors to get our moneys worth unfortunately we set up our shop after the switch over to subscription. Does anyone know of an alternative?
    Also on the same note I want to be able to run my motors. Mitchell provides the TI-3000 system to do this but again its subscription - I need a universal motor run system.
    Any thoughts?
    Dec 2015
    4
    Re: Alternative to Mitchell Electronics TI-5000
    Hi, did you find a alternativ for the equipment from Mitchell Electronics ?
    We are planning to build our own equipment !!!
    Regards from Denmark
    Oct 2017
    15
    I haven't - did you end up building one?
    Dec 2015
    4
    Yes, We are building one right now.
    We are using aS7-1500 and converting all signals to hall and then we are using a drive from AMC like mitchell.
    it is better you can them use TTL, Htl , resolver, Endat 2,1 - 2.2, hiperface and hiperface dsl, biss, drivecliq, mitsubishi, fanuc and etc.
    https://www.cnczone.com/forums/attac...d=458998&stc=1
    Quote Originally Posted by elektromann View Post
    how does it work?
    replaces the Mitchell well?, Did you get it to work well?
    Mar 2021
    3
    Hello elektromann,
    we need an alternative for the ti5000ex. Can you offer us your system ?
    How does it works ??
    Thank you
    Mar 2021
    3
    Hello Together,
    i work in a repair shop and we depend on the Mitchell Box. Does anybody has an alternative solution ??
    Thanks for ideas, etc....
    Regards from Germany
    Dec 2015
    4
    Hi again
    I will write in here when we are finish Building the test reg.
    So fare it looks promising :-) have a nice sommer :-)
    Oct 2017
    15
    Hi Elektromann did you finish it? I have DM'd you but no reply. Maybe you could reach out. I think I can help
    Hi again
    Jan 2022
    Curious has anyone used or heard of Octava Engineering before? Look to have similar repair equipment for servo motors.
    Oct 2022
    4
    I am also interested on this.
    Hi Elektromann did you finish it? Is there a way I can buy your system?
    Best regards,
  1. Retrofit Prolight 5000 (Benchman 5000) to run Mach
    By Impyman18 in forum Benchtop Machines
    Last Post: 07-10-2019, 04:12 AM
  2. HSP Alternative????
    By jrmach in forum BobCad-Cam
    Last Post: 09-17-2012, 10:37 PM
  3. PIC Alternative
    By Lston in forum General CNC Machine Related Electronics
    Last Post: 07-10-2006, 08:35 PM
