552,894 active members*
1,658 visitors online*
IndustryArena Forum > MetalWorking Machines > Bending- and Punching Machines > AMADA NC9-EXii alarm code 408 (on RG100)
    Mar 2009
    4
    Hello,
    I have an amada rg100 with the NC9-EXii cnc controller. I have the manual for both the controller and the machine.
    (my apologies, but I am a noob)
    While working through the manual on how to program the controller, I entered all the data for the
    V opening
    Thickness
    Tensile Strength
    Punch Radius
    Die Radius
    Die Angle
    W Flange Dimension
    Angle
    Bend Length
    When I press INP to input this into my process, it ALARMS with 4 08
    I assume there is an error I am doing in entering my data?
    is there a list of error codes available for this controller? My google-fu was not able to find one.
    Mar 2009
    4
    Re: AMADA NC9-EXii alarm code 408 (on RG100)
    Ah found it, it was in the manual
    alarm 4f08 my angle calc is incorrect.. now to go figure that out...
