please help
I have problems amada pega 357 04pc
in turn I get system error
We have motherboard
built on and off then comes the turn on
system error
how I can
please help
We have motherboard
system error
how I can
which system error? Are there lights on? Does the screen say anything? Be as specific as possible.
yes I have deleted memory
machine was again 0
right page button MEMORY TAPE MANUAL EDIT MDI is off
system restarts
said parameter active and alarm 417 427 437
all parameters re-entered
then I can not disable parameter
I give 0 not go
but I have punched tape parameters
tape reader not funksioniert
how can I bring back machine run
did you also enter the DIAGNOSTIC (300~650) parameters?
DIAGNOSTIC (300 ~ 650) parameter
I entered manual
now I've turret and index problems
alarm in 2000 and 06 interlock
and no alarm in 2009 how I can
I need no parameter which
I have to change parameters
There are 2 errors which which we are getting with the machine
No.-222 +Y S LMT
And when we are correcting that error another error is occurring
No.-220 +Y OT
These error are regarding some parameter settings, may be these error relates to PARAMETER numbers 81, 82, 83, 84.
Can you let us know what this error is and if we can find complete manual which will tell us what to do.
we have no manuals for this control; found a link for saving and restoring macros/data:
Search Results for FANUC 04PC PARAMETERS.pdf - Download Free Ebooks - EDocFind.com
Alarm 222 is software overtravel 'the +Y stored stroke limit has been overstepped'. What condition caused this? Programing error? Jog error while zero referencing?
Alarm 220 is 'the +Y stroke limit switch has been activated'. In manual mode hold overtravel release until NC Ready indicator is on and jog the Y-axis using -Y jog button. Then reset to clear the alarm.
Be very cautious about changing parameters. Make a backup of parameters before you change anything. Parameters 82, 83, 84 are gridshift parameters for X, Y, T axis.
Hello,
I would like to know your opinion on these two machines: Amada vipros 357 and amada pega 357.
Which one is better, more friendly and easier to manage, less expensive maintenance, etc?
Thanks!
I've never had a vipros only have a pega 344 so I can't tell you about those but I like my amada. It has served me well with the Mate and Wilson brand tooling I bought. I do a lot of flat pattern parts with it
The Vipros 357 is my choice.
The benefits of the PHNC hydraulic control makes for easier setup for marking, forming and embossing tools. The punch hover feature reduces run times on jobs.
I also have an Amada Vela 355 and Amada Aries 222. I would prefer the hydraulic punching machine instead of the flywheel type.
Downside is ~ $ 1.5k for filters and oil change each year.
Hi
As per my opinion you just take a look of AC Servo machine insted of Hydraulic Servo b'coz Ac Servo is better for less power consumption, more productivity, more friendly and easier to manage, less expensive maintenance.
Regards
I have an amada pega 357 with fanuc 04p control. We have had lots of issues and this machine is new to us. I need some help. Today when trying to run a program the machine just stopped and the clamps released. Ive tried to reset and do everything I know how but I cant get the clamps to close. The foot pedal has no response.
I dont know my way around the machine well enough yet to even know what fuses, breakers, cords, etc to check. Can give me a list of items to check or troubleshooting procedure
I did notice that usually when we power on the machine the control usually comes on, then the hydraulic, then there is a multiple clicking sound that I believe may have been the clamps, after the clamps stopped working that sound no longer happens.
please help. Ill even pay for tech support if someone can offer it and truely knows this machine.
email or text
618-709-9262
[email protected]
Hello!
Can you please send me Diagnostic parameters for Amada Pega 345 Fanuc 04pc controller to my jayratio at gmail . com
That will be a great help.
Thanks,
Ajay
Dear Jai
Download it from here
CNC Manuals: Fanuc Manuals Part2 - CNC Manual
Hi !
Thank you for referring that link, but that does not contain Parameters or Diagnostics for Amada Pega 345 Queen with Fanuc 04PC Controller.
Regards,
Ajay
Is it turret punch ? or
Yes, it is Turret Punch with 58 stations and 2 auto index. 6L C Servo motor.
hi jay,
what exactly is the problem with your machine...?
let me know..
thanks.
Hello Pitre,
Everything is in order now, only one problem, x is 1mm under travel, mean I have to add 1mm to achieve desired position.
Hope you can help me resolve it.
Thanks,
Ajay
