Having issues with the Amada Vipros 255 PHCN 2091 alarm?
First check the tunning, Hydraulic flow control valve, servo amplifier flow control valve,
How change chinese display to english phnc amada
Hi there Im having a PHNC alarm (2091)
whene i go to phnc screen it gives me the following:
(1/2) --Message : top dead center sensor alarm
--details : no TDC signal came up despite the ram is in that position
--check the TDC sensor, then press the reset button
(2/2) --message : 09 servo alarm
--detail : the servo tolerance is over the limit, while the punch is idling
--solution : check hydrulic unic, servo valve and servo amplifier
